Dragonfly Red and Jitterbug with the Dragontail are well worth it for mobile DJ's or PC enthusiasts!
Fast, easy and mostly cheap priced, very high quality audio output..
Studio listening:
Mixer: Alto ZMX 122FX (built in FX processor turned off)
Speakers: Klipsch - ProMedia 2.1 Speaker System (mixer mids @ 25% - 45% from 0, bass at 30% - 50% from 0, treble @ 50% from 0.
Cabling: Livewire Elite Interconnect Y-Cable 3.5 mm TRS Male to 1/4" TS Male
Thinkpad t430s (w8.1) onboard sound, to Creative SB1240, to Dragonfly Red, to Dragonly Red w/ Jitterbug, and the journey upgrading each time.. has been pretty amazing..
Song files, even 128k bit-rate sound drastically upgraded and improved on the Dragonfly Red w/Jitterbug.
When I take the Thinkpad to performances with the Dragonfly Red, on larger stage speakers, the difference is very noticeable. The SB1240 did a better job routing the audio to the mixer than the onboard sound, properly separating L/R channel and low pass for the physical control boards on mixer and 'pass through' board on sub. But the Dragonfly Red takes everything to a completely new level, mids are cleaner and don't blare, for example.
I've had to listen to songs and mixes, thousands and thousands of times, over and over again, in lots of settings and different speakers and setups. At the price of what a Dragonfly Red and Jitterbug will offer, paired with the right equipment, I say it's well worth it.
For MSRP $267?
Dragonfly Red, $200
Jitterbug, $50
Dragontail, $17
...Can't go wrong here. Compared to some of the really expensive sound processors that run for over $1K that DJ's lug around, just to achieve "stable interconnect" for stage/venue equipment? The Dragonfly Red and Jitterbug achieve a lot of that, easily, as a bypass; just blows my mind.
Doesn't replace microphone processor(s) for DJ controllers or sound mixers, but that's a different subject.
I just read the manual for the Jitterbug, and it recommends that end-users should plug in two Jitterbugs at most per device, one per USB controller, if I'm reading that correctly. People are posting that AQ wants customers to potentially plug the Jitterbug into every port of a computer, and that seems absolutely ridiculous.
And if audio sounds worst with the Jitterbug, it's probably because of the many different variables involved.
Like someone mentioned earlier, Jitterbug + Dragonfly, will yield, personally, the best results for audio listening output where listening experience can be appreciated or needed, per-user.
Dragonfly Red will speed up the music without tearing it unless the song was already torn in the first place, it just becomes much more audible. But with the Jitterbug, it resurfaces the clarity of the audio to allow DJ's to better hear every split second of a song or sample, you'll hear even more details or flaws in the sound files.
Can save a lot of time, cuts down on potential mistakes during split second splices from sound interference, all without having to shell out extra hard earned cash on expensive, unnecessary hardware upgrades.
For PC enthusiasts or mobile DJ's that want extremely reliable audio output? Look no further, Dragonfly and Jitterbug are a great pair.
Worth it? YES...
