Anaxilus
- Mar 12, 2010
p.s. As far as mW output is concerned, the Cube C30 is stated having a MAX9722 Amp with up to 130mW output.
Admittedly I don't understand mW ouput very well, almost every sony DAP I've seen simply states "5mW+5mW" and I doubt the Cube C30 has 13 times the power of a 6 times more expensive Sony.
For the record, S:Flo2 states "L(10mw) +R(10mw)(32Ω)"
My Sanyo PCDP which is my primary DAP at the moment states "5mW+5mW at 32 ohms"
it then continues to state "1Vp-p at 75 ohms, recommended load impedance 75 ohms" in the video output jack.
All I can say is this PCDP is loud, using A-Jays Three (97dB @ 1kHz, 16Ω) listening to a CD I usually select 7 / 32, 15 / 32 is deafening loud.
I listen at loud volumes, for comparison, on my sony gumstick DAP, I can listen at max volume for half an hour or so (30 / 30).
I'm almost scared if I get the CK10's in Singapore I'll just break them with one of these powerful DAP's and my high volume listening habits. =p
CK10 is 55ohms @107db. Its not going to break either inside or out. Your ears will break first.
