Robert Drea
- Jul 15, 2003
Actually, 88.2 khz files are in common usage among studio recording technicians as the resolution is exactly twice that of the 44.1 khz Redbook standard.
Does it play 88.4 kHz files?
The tech info only states 96 kHz.
Nuh uh. All 3 models in the HM series do not play 88khz files. I met David Chesky and asked him why he chooses 88.1 over 96 on some of his downloads and he said it has something to do with the original recording masters.
On the CD that was made exclusively for Head-Fi there us a track (I believe it is #8), it skips right over it. But there is simple software to change the rate for the HM series.
Thanks, that was a sad but clear answer.
I don't know how well these resamplings perform SQ-wise, so I thought I might just make 88,2kHz files into 44,1kHz (24bit).
However that would turn a hi res file into something close to a standard cd format (except for the bit depth).
What software would be a good choice? (preferably free, that is)
What sd cards work best for the 601?
larshp, there's a lot of software for transcoding, and it depends on what kind of computer you use (and in some cases what kind of input and output formats you have, not all software I tested does all formats, or all formats equally well). in the end one major reason for me to get a hifiman hm-601 was that it's easiest to have hardware that plays hi-rez software, whether your own recordings at higher rates, or audiophile downloads. - however, I forgot which label was making it available, but I have some 24-192.flac test files from a high-rez record label website that I tried to convert to various other formats, including one that would play on my iPod, and I'm not convinced I've found the one best software for all such tasks. currently I like both Max and XLD, which you find compared at many sites, including here: http://www.makeuseof.com/tag/audio-converters-for-mac-max-vs-xld
Thanks for your input. I don't use Mac, so I don't think I can use the software you recommend.
What I am looking for is a software that works on Windows and is able to convert f.i. a 24bit 88.2kHz FLAC file into 96kHz.
My initial concern was and is a theoretical distortion(?) when converting 88.2 into 96kHz.
Try this theard..the compatibility with 801 seems to be the same. I use Patriot 32GB class 4 SDHC card.
Hi everyone,
I'm a HM601 Lover, and i use it with great delight with my Earsonics EM2-Pro.
The only annoying thing to me now, is that my files are shown in disorder. Which TAG do i need to delete if I want the Hifiman to display tracks with correct alphabetical order (ie. 01 - track1 / 02 - Track 2 / etc ...)
Many thanks in advance, i made a research on the topic, but i did not found a clear answer to that.
Fantastic sounding player btw, my J3 is really no match for him.
How is the bass on the HIFIMAN 601? I like electronic, electro, breaks, metal and rap so I am after the sub bas shaking in my ears. thanks all.
