Thanks it works
REVIEW: HiFiman HM-601
- Thread starter LFF
mechanix
- Jun 9, 2010
I just bought 601 with re400 for $116
Is it a good deal? This is my first DAP.
Does anyone know other good deals like this one? All i am getting is prices around 250 bucks.
Headphone4Life
- Jan 22, 2015
I recently bought a Fiio X3 Gen 2 and while I like it I still think my 601LE (its really a 602 with 4gb less memory) sounds a little better, I think.
The 601LE has a more forward midrange which for me is great as it bring them out more in my Sony Z7 which has become my favorite headphone. The bass also has a bit more thump over the X3II but the Fiio's bass sounds a little cleaner. Its really close but I think the organic, warm and smooth sound of the 601LE takes it just over the X3II in SQ but the X3II has a better UI and gapless playback which I love as I have a lot of tracked Dj mixes, so over all I think its even. I want/need to sell one but don't know which one yet so I guess more "testing" is required
ozkan
- Nov 1, 2012
+1 on 601 as they sound more natural. I couldn't find anything special in X3II.
ph58
- Jan 2, 2014
Hi guys is the LO of the HM601slim 8 go a true LO that bypass the internal amp ? Thanks in advance .
Shawn71
- Aug 18, 2013
Yes, all the LO of DAPs does that....the o/p stage of DAC.
ph58
- Jan 2, 2014
OK thank you .
Shawn71
- Aug 18, 2013
OK thank you
Set Amp (HP/stereo) to zero dial before hand, connecting to IEMs/HPs (load).....just sayin.
deppechmode
- Apr 5, 2016
HM601LE rockboxed has better sound quality than stock rom ?
gimbertt
- Feb 23, 2010
It sounds just as good but Rockbox works far better.
deppechmode
- Apr 5, 2016
HM601LE support sd memory 64gb or 128 gb ?
If you format the card as FAT32, a 64GB SD will work (that's what I do).
deppechmode
- Apr 5, 2016
Thank you for your reply...how about 128 gb for stock frimware ?
deppechmode
- Apr 5, 2016
Is there anyone confirm ,stock rom support 128 gb sd ?
- Mar 30, 2012
So let me say this, my LG V10 just crapped out as my music player due too... well updates
that said, I've got a Rock Boxed Little HM601 lying around that I don't use all that much but paid $100 for, non the less I also noticed my iPod isn't sound as clean as it used to either :/
SO thankfully I learned a little about how to properly run a graphical EQ, I put my settings from neutron android into the ROckBox EQ settings and LOW and BEHOLD... it sounded a little better than my Phone does [but that's an ESS Dac VS a NOS BurrBrown with an already metallic headphone]
Either way, I'm REALLY glad I got this little guy yea my HM901 sounds WAY better but I don't want to carry that to the gym nor do I like to EQ with that kind of pricy gear, but my HM601 to HD 25-1 makes a great gym rig!!
