I've been using the TD-11 for about one year and I've dealt with two types of serious noise.
The first is the fuzzy static sound which is common when the TD-11 is cold. I also sleep my Asus netbook by closing the lid (not hibernate), so it's never getting a clean boot. I've always suspected a connection between the noise and sleeping the netbook, but I am also able to reproduce this in windows w/o music [while it's cold] ...
1. right-clicking on the volume control in the system task tray, and choosing "Playback devices"
2. right-clicking on a device in the "Playback" tab, and choosing "Properties"
3. switching tabs to "Supported Formats" (see image below)
4. clicking on "88.2" or "96.0" and hitting the "Test" button
This fuzz noise I suspected to be jitter, but I have no idea what jitter sounds like. Really wanted an Audiophilleo-1 to test this. I also suspected that maybe it had something to do with the Yulong driver. I keep the TD-11 near my preamp with short interconnects, and my netbook at my listening position. So I had about 15ft of junk USB bridging the gap, when in practice USB shouldn't ever go over 2 meters (I read USB is good for 10ft, coax/rca/bnc SPDIF 30ft, and balanced SPDIF 300ft). This was a great excuse to grab a JKSPDIF MK3 off audiogon! While the TD-11's SPDIF input does behave better than the USB input, I was still able to reproduce the fuzz [while it's cold] through SPDIF, and I did so on a Core-i7 workstation. But after a warm up the SPDIF input can play a clean test tone at 192khz! I use a 17ft bluejean spdif cable and I only use the TD-11's DAC out.
There is a second [more troubling] sound that may have nothing to do with the TD-11 or it's driver (definitely not the wires). When I hit the play/pause button on a multimedia keyboard the sound pauses. When I try to take it out of pause by hitting it a 2nd time I get an extremely loud white noise sound, that actually killed one of my VIFA midranges. I lived with this for so long that I became conditioned never to pause my music. This was the first thing I tested with the JKSPDIF and there is no such danger. I suspected my OS might be to blame for this -- I was using the Windows 7 x32 Starter Edition that the netbook came with and this weekend I finally reformatted with Win7 x64 pro. Before the reinstall I assumed that my N550 atom cpu was junk and the pre-installed OS was the best performance I could expect. Not so! Some tuning steps I recommend for a dedicated audio pc are disabling onboard audio in the bios, omit any software that might require updates (like office and antivirus), uninstall tablet components, and uninstall all microsoft media features (dvd maker, media center, and media player).
SwanSong:
I don't have a great ear for small changes in the signal path (cable changes are almost lost on me). I also don't have any music over 96khz. But sound difference aside, I do think the TD-11 behaves better on it's SPDIF input. My friend has a more expensive equipment chain including the W4S DAC2 and the both of us couldn't hear the difference between it playing on junk USB vs the JKSPDIF. We easily sent a 192khz test tone into his USB port where the TD-11 can only do that through the SPDIF. I will say that on my system (TD-11), when you don't use the RF attenuator the sound change is minor. But with the RF attenuator I definitely noticed that much of the harshness was lifted from the music's peaks and loud passages (my Thiel speakers have a bad rep for being bright). With the peaks tamed it was as if the subtle secondary sounds were now playing louder (and the milky way reveals itself in the absence of light pollution). This is the type of improvement I expected from better interconnects, but the attenuator impressed me most.
Project86:
(while we're on the topic of hibernation)
JPlay is supposed to have taken clean playback to extreme lengths, and one thing they are offering is playback IN [what they call] hibernation mode. Hibernation is clearly the wrong term, but if the computer is indeed reaching sleep mode while continuing playback (although with zero keyboard control) than that's impressive. Sadly I couldn't hear the difference between JPlay and Foobar but I was happy to make the purchase because I appreciate his goals and methods, and maybe one day my system (or someone else's ears) will be good enough to reveal the benefits of JPlay.
