8xOverMsOctober
- Jan 23, 2009
Oh, I missed the Rock/Metal/Alternative part. That's pretty much all I listen to.
Especially for metal, speed is important. If you don't have the right speed, things begin to sound a little sloppy compared to how tight they sound with fast IEMs. I never realized how important that was until I heard metal with quick IEMs. I doubt the C3s have any trouble in that area though, being armatures. Dynamics are sometimes too smooth for metal, and don't have that quick, defined punch that helps give quick parts definition.
Bass just needs to be present when it should be and should have impact. The RE0s were alright for me, they just needed a little more impact. So, bass quantity isn't a huge deal, as long as it's not missing.
Something with a present mid helps guitars out a bit.
The highs I think are subjective.
If your equipment is revealing, crap in crap out is how it goes.
I think the most important thing is not to get something boring or that you can't tap your toes to. If you aren't enjoying the music, you won't be headbanging when appropriate.
The C3's are quick enough, but their sound signature leaves a little (just a tiny bit) to be desired. In my Rockboxed Fuze I set the bass to -1 and the treble to +1. It's not that big of a deal, but I hate EQing. I had a set of NE-7M's for a bit over a year and loved them (for dynamic driver IEMs) - their sound signature was great and I didn't have to EQ them at all.
The C3's aren't as forgiving as the 7M's were (probably true of a lot of balanced armature IEM's - and seems to be true for the DBA-02'ss as well from what I've read in this thread). Some songs that I love sound like garbage with the C3's, whereas those same songs sounded pretty good with the 7M's. It was really an eye-opener for BA IEM's. On the other hand though, there are some songs that sound absolutely phenomenal with the C3's.
The cable doesn't bother me to much with the C3 (though it can be noisy at times), It's the fit that I have a problem with. Even with using really comfortable sleeves with them I can only use them for 1 - 1.5 hours max before I need to take a break from wearing them because they get so uncomfortable.
Reading about the cable and fit of the DBA-02's makes me want to try them out just for those reasons alone
Thanks for all of your help!
