gnarlsagan
- Sep 11, 2011
lmao.... Makes me wonder if that's why they charge such exorbitant prices for these tips to cover for the shipping and size of the box .
Someone who has both the auvios and ortofons, what are the differences concerning stem length (= insertion depth), density/hardness/flexibility, resonance frequencies/sound signature for ASG-2. I've been tip rolling a bit more but still not satisfied. Got rid of maybe 20% of the sibilance with an OFC IC instead of pure silver and noticed that softer, shallower silicone tips give less sibilance than longer tips with harder stems. Going to try the short biflanges from IE8 since they're really shallow and maybe apply a Hifiman filter from Re0. After 300h the sibilance is a little better. Still really sensitive to sibilance and will show if there is even a trace of it. But some songs and albums sound great. I think I'll stop burning them in now. I'm getting sick of the little "pink noise and dual sine sweep".
I just downloaded Ben Howard's Every Kingdom album and it sounds amazing. The ASG-2 takes it to another level with the clarity, bass, enveloping stage, and vocal intimacy.
You think it sounds good on the G2.. I'm listening to that album w/ the Crack+HD800..
LAWD.
LAWD.
Eke, when will Aurisonics give us an upgrade cable? if i am not mistaken you once mentioned Dale was working on it, right?
hopefully they do, ASG2 is too good IEM and deserves a better cable.
I do remember reading something about an "audiophile" version of the ASG-2 with an upgraded cable.
Does anyone know how to lower the volume on my ASG-2s? I know theyre very sensitive but I have set my volume slider to the lowest I can get it at and only go one click above silent when listening to music on the stock music app. I am using an iPhone 4 btw. Any apps that have a more precise volume control or is there any better solution? Thanks and still enjoying every hour with these iems
