Pricklely Peete
Franken modder
- Feb 17, 2008
I would imagine the ROC might do very well but then again power hungry cans can be a surprise in this regard (may need more power may need less). Current delivery is also a consideration for such hybrid transducers but the ROC may have plenty of reserve current on tap or it may not, again my advice in this matter is not much help sorry to say. I do know the K1000's need a beefier amp than the Phoenix which has a bit more power on tap than the ROC.
Here are the power ratings for the ROC into various loads
25 ohm: 750MW
62 ohm: 1800MW
100 ohm: 2500MW
300 ohm: 1350MW
600 ohm: 700MW
Here is the link to the spec's page н¨ÍøÒ³ 1
Is there any way you can borrow a set of K340's to see if the ROC does the job to your liking ?
I would strongly suggest the K340's be re cabled for balanced drive ASAP since the difference in power and gain levels are considerable between SE'd and balanced operation, but I bet you already knew that by now
Peete.
Originally Posted by realmassy /img/forum/go_quote.gif Roc owners, what do you think about using this amp to drive a pair of balanced AKG K340? These are pretty inefficient cans and people tend to use a speaker amp. |
25 ohm: 750MW
62 ohm: 1800MW
100 ohm: 2500MW
300 ohm: 1350MW
600 ohm: 700MW
![smily_headphones1.gif](http://www.head-fi.org/forums/images/smilies/smily_headphones1.gif)
Peete.
