I think he mentioned to me that he was hoping to have his business up and ready at the end of November, but he's got an awful lot to inventory, a website to setup, and had a lot to uncrate. I hope he's successful as he has a lot of gear I haven't seen since I was a little kid. He may go into selling new production tubes, too, so there will be more options for us North Americans than just Grant Fidelity
He's considering various lines and is assessing what's already out there to cut down on redundancy. From my interactions with him, he's punctual and has integrity, so it's only a win for us consumer guys if he gets his business going.
The cheapest tester I'd recommend getting is something along the lines of a B&K 747. A used one will go for $200-300, followed by another $200-300 for refurbishing old parts and calibrating the tester. If you want to go high-end, there are the Hickok 539B/C ($800-1100) models. The vast majority of testers (especially out there on ePay) are inflated by 200-1000% what you will pay at a swap meet or an old shop, and most of the comments about 'worked when I last tried it' 'seems calibrated', etc., are outright lies.
Not only that, unless you have an adapter, you probably won't be able to test all the tubes you want (older WW2 models like the TV-2 will definitely need an adapter), and those era testers will not test something like a 300B properly because the tester won't be able to drive enough voltage. The tester will not be able to simulate an equivalent setting as the demands of an actual audio rig.
If you want to do it right, you'd want an Amplitrex AT-1000, which is $2675 (http://www.amplitrex.com/about.html) or a cardmatic tube tester to do traces. An Amplitrex will probably do everything an audiophile could possibly want, and will be more accurate than even the laboratory Hickoks/Western Electrics. The 539B/C are legendary testers but are not really accurate compared to something like an Amplitrex. The high-end Hickok reputation has far outsold the actual value at this point. Conversely, you want to be careful about the low-end testers to do anything more than a gas emission short test. Most are not that accurate and just not very good. There's a reason why Hickok supposedly owned over 70% of the market.
I'd just recommend finding someone local like this guy to do a proper curve trace for you.
