pr0b3r
- Mar 18, 2016
After spending several days with my P1 and attempting comparisons to the G1 by memory, I can say that in the stock configuration, the P1 is brutally neutral and honest, and will, without apology, reveal any source file warts or shortfalls. It is not what I would pick if I just wanted to chill and daydream, however given quality recordings, it will sing with a clarity and honesty that is matched by very few players, regardless of price.
Although it is opamp-rollable, simply changing opamps at random will not make a night and day difference in the SQ. Much of what we hear is a synergy between the active devices (DAC, opamps, etc) and the many other circuitry components.
In my opinion, the most important sonic characteristic of any music device is accuracy of timbre. If, for example, a piano doesn't sound like a piano, nothing else matters, including frequency response, imaging, distortion or any other measurable or psychoacoustic factor.
The P1 circuit design does produce very accurate timbre with instrumental, percussion and vocal voices. Given the accuracy of this most important factor, we can consider other issues such as imaging, soundstage depth and width. These factors can be shaped to some extent in an amplifier circuit by the correct choice of active components, such as opamps, tubes, etc. As the perception of soundstage depth is primarily due to the difference in amplitude between instruments or vocalist front to back, an opamp must be able to play accurately and evenly at differing volume levels simultaneously. (In live performances, our vision also helps our ears to accurately perceive a sense of depth).
With all that said, I found the stock sound to be a bit brash and assertive for my taste, as if I was seated in the front row of an energetic performance. For those whose genre of choice is rock, this will likely prove quite satisfying. My preferences lean more towards classical and acoustic music, so I spent considerable time searching for an opamp that might be able to shade the sound a bit more to my preferences.
When evaluating opamps, some general guidelines to be observed are matching voltage requirements to supply voltage, low distortion, low offset voltage ( which can often be heard as a scratching sound when rotating the volume control without music playing) and, IMO most importantly, the ability to reproduce a perfect square-wave response without pre or post ringing. Any appreciable ringing can be perceived as a harshness or brittleness in percussive transients. There are relative few opamps that can actually reproduce a clean, accurate square-wave. Invariably, I have found those opamps which can to have the most natural and pleasing sound, especially when installed in a circuit of good design (which the P1 clearly possesses)
I used the following phones and IEM's to evaluate the P1 during my numerous sessions of opamp rolling: AQ Nighthawk, q-Jays v2 (dual BA), Pinnacle P1 (dynamic driver), Shozy BK earbuds, and MG5Pro {custom dynamic) IEM. I used only .wav files including various orchestral instruments as well as male and female vocalists with whom I am quite familiar. I also used some binaural recordings of thunder to get a sense of extremely low frequency ability.
Upon opening the case of the P1, I discovered that it is the bottom that should be removed, leaving the top with the buttons still attached to the front and back plates. Once uncovered, it revealed a beautiful board design with much attention clearly devoted to optimum component layout. The DIP socket for the only rollable opamp has a cap near each end which may pose a space issue for SOIC opamps soldered to an adapter. A good option is to use a DIP style opamp, taking care to ensure that it is a DUAL-channel and is inserted correctly.
Not being a big fan of the stock Muses opamp series, it was my goal to search for something smoother that delivered a presentation that moved me a few rows back when listening at my normal volume level.
Some of the opamps that I evaluated and made the cut to the finals were the LTC6241HV, EL8201, AD744, AD8616, and LME49860.
I felt that all of these delivered excellent overall performance with modest power requirements. None of them noticeably changed the frequency response, but rather made subtle changes to imaging, soundstage width and depth and perception of realism.
In the end, however, the overall winner was the AD8022. It has close to perfect square-wave response, very low distortion, extremely low-noise, high output and low quiescent current, in other words, about everything one could desire in an opamp used for audio purposes. I am pleased to report that when installed in the P1, it sounded as good as it looked on paper! Very smooth, with no frequency spikes or drops, bass that is almost palpable and a sense of realism that the others didn't quite deliver to my ears! Try it, I hope you will like it as much as I do.
Your feedback makes me want to have one, either the G1 or the P1. I just posted a screen grab of this on our local group. Thanks @HiFlight!
