HiFlight
Welcome back, TJ! Good to see all is well with you!
Hi, I'm sorry was inactive for a while.
There is much business that I need to do in my company, so I must inactive in audio works.
Actually, I was work on another audio stuff but still not finish.
Some Revamp Acoustics project that still on development is G2 Audio Player (for this I'm not sure I can finish the project or not) and also USB DAC (for this project I still continue the development)
Still can't find the time to continue in audio works, so sorry..
Regards,
TJ.
best wishes TJ
you created allot of smiles in the world
that's the best anyone can hope for with what they love t do
Hey TJ,
Glad to hear from you TJ.
I know how hard it is to get a new company off the ground. Keep at it.
If and/or when you have audio gear for sale, we're here to support RA.
Thanks, I didn't expect Revamp Acoustics will have a loyalist. since my product is far from perfect mostly in the aesthetic side
I'm still developing a new product, but try to manage to get a better solution for me and also for the users.
Letting the user can DIY-ing like rolling opamp must sacrifice the dimension of the product and also expected will faster the unit will be broken.
I don't know the future product like the USB DAC that I was mention before will have the same response from users.
The smartphone is more capable of playing/streaming such a high quality of audio this Days, so I started designing tiny USB Type-C DAC since last year.
Here is the mock-up for what finished product will be:
Regards,
TJ.
My 2 cents:Thanks, I didn't expect Revamp Acoustics will have a loyalist. since my product is far from perfect mostly in the aesthetic side
Flashing (or fading as the manual calls it) indicates a low battery.Been a while, but I just picked up a P1. I downloaded the latest firmware, followed the readme instructions. The notification LED is flashing red for about 1/2 hour or more. Is this normal?
Perhaps an improperly formatted SD card?Been a while, but I just picked up a P1. I downloaded the latest firmware, followed the readme instructions. The notification LED is flashing red for about 1/2 hour or more. Is this normal?
Is there an SD card in? I remember it flashing red if it has an improperly formatted SD card. It will fade red if the battery is low.That's odd, the charge light is green when I plug it in.
https://www.makeblock.com/project/mbot-li-polymer-batteryDid anyone ever find a replacement battery on Amazon that does not require swapping wires?
