docentore
- Feb 27, 2013
invalid statement as I have many iems and it drives everyone I have tried balanced or single endedI cannot see that ES100 wouldnt be able to drive any IEMs. It should be able to push 0.2W into 16Ohms - that is a lot of power.
Yeah, looks like he misread your post and actually agrees with you.Sorry, did you just say that all IEMs that you have you tried with ES100? And?
However, in the case of Tin Audio P1, it is a planar magnetic IEM that actually does need as much power as an inefficient full size headphone.
I used it whit the battery care mode 1-5 hours a day since feburar this year a d did not even notice any change on the battery lastMy units battery is already bad after buying in May. It is only lasting 3 hours at best. Contacted radsone about issue. Waiting for a response. I really like the es100.
My apologies I did in fact misread your postSorry, did you just say that all IEMs that you have you tried with ES100 with ease?
Why my statement is invalid then if I basically said same?
It's all good, good spirit explained in the pm where the confusion wasMy apologies I did in fact misread your post
Yeah I forget who said it but I think I was the first to agree with him hahaI had a chance to play with the DCT setting. Whoever said it sounds better with DCT off is right. I definitely like it better with DCT set to OFF.
Thanks to whoever recommended it
I think it was meYeah I forget who said it but I think I was the first to agree with him haha
What was your source for the 58x before this?Just got this little bugger last week. Software and app support is top notch. im treble sensitive and its definitely smoothed out the hd58x's treble for me (less piercing/vocals are less harsh). its pretty almost perfect except that im getting around ~350ms audio lag when using youtube/vlc (I can fix it manually on vlc). I still get the same lag even if my buffer length is at 0, 1, 3, 5, 7, 10. What is interesting to note though is that for the first minute or so there is no lag then after that the lag gradually increases over the next minute until its ~350ms behind the video.
also is there a case/sleeve for this? I'd surgically implant this thing into my chest like Tony stark if I could to protect it since I use it almost all day.
