Radsone EarStudio ES100
Discussion in 'Portable Headphone Amps' started by m4rkw, Dec 12, 2017.
336 337 338 339 340 341 342 343 344 345
347 348 349 350 351 352 353 354 355 356
  1. subwoof3r
    You're not completely wrong, will do that. thanks for your input
    Thought the support was directly Radsone and not amazon
    *edit* : just checked on Amazon, its only possible to send back for a refund and re-make an order (at more than 150$ for the actual new price!), no direct replacement, this does not arrange me in reality..
    peter123 likes this.
  2. peter123
    I'm sorry to hear that. I agree that Radsone should step up in that case.
    subwoof3r likes this.
  3. lgcubana
    While not the best solution (monetarily), it would probably be less expensive to buy a replacement cable, either on Amazon or maybe even locally.
    CactusPete23 and subwoof3r like this.
  4. subwoof3r
    Yup you are right, will do that. It's just I really liked the short version of that included USB cable. Too bad for me :)
  5. Alphasoixante
    It's going to be much faster and more convenient to return via Amazon. It's a total breeze - they even pay for return shipping if you choose "defective" as the reason for return.
    Edit: I thought I was reading the end of the thread when I wrote the above - pls disregard.
  6. Alphasoixante
    Hi all.
    I'm looking to buy another ES100. Please see my wanted, or PM/DM for details:
    Edit: never mind - a generous friend is giving me theirs.
  7. lgcubana
    There are only two reasons that come to mind, for why someone would want to sell their ES100: they have Tin P1s or their battery is depleted
    For $85 you can get a brand new one on Amazon
    Broquen likes this.
  8. Alphasoixante
    Yep, I'm aware of the price.
  9. Slater
    You forgot 2 more reasons:
    3rd: Insanity
    4th: Deafness
    capnjack, docentore, lgcubana and 4 others like this.
  10. Broquen
    And I'll post soon my impressions, but same should be applied to HE100. First hours listening to them after 15h. of burn-in, and have to say that it have been a very gratifying experience.
    HungryPanda likes this.
  11. zolom
    BTW, is there an option to replace the ES100 battery (DIY)?
  12. capnjack
    I know the ES100 doesn’t have much/any headroom with the P1 but it’ll work fine with virtually everything else though. Definitely a keeper for me :wink:
  13. peter123
    Is it a fact that the ES100 can't power the P1 properly even from the balanced output?
    In that case the P1 must be the hardest to drive IEM's in existence....
  14. rkw
    Opinions are mixed. It is generally agreed that amps with more power than an ES100 would be better, but some have found ES100 in balanced + 2x voltage mode to be adequate for them.
    Philimon, docentore and peter123 like this.
  15. serwei
    I'm using the Earstudio to power my Ananda lol. Using balanced with double voltage, which is the same as nonbalanced with double current actually. Extremely loud at -3db, but battery life drops to almost half the normal rate.
