LTDJ
It was guuuud. Very super, much loudness.Anyone tried using the built in mic of es100 here? How was it?
I see. Thank you!It was guuuud. Very super, much loudness.
The weird thing about the Meridian system in my car is that it doesn't play FLAC. You would think a higher end system would do better than just MP3.
Yes, I am kinda addicted on building new cable for the ES100.
Does the ES100 often go on sale?
Hi, I recently received ES100 bought by amazon. It was great for 2 days, equalizer is really good with iSine 20 and qJays 2nd gen. As I came home, I upgraded it to latest FW. few minutes ago I wanted to modify a bit eq settings, but I was unable to turn on ES100, when I plugged it to USB, it shows in the app 1% and charging completed, after few seconds it jumps to 100%. Unfortunately with disconnecting from USB ES100 immediately turns off. No way to turn it on without plugging it to USB. I even thought that flashing it again could solve the situation, but there is no way to get it to this state. Did anyone had this issue?
What material are you using and and how much are you charging?
Tried factory reset twice and also various cables for charging. With that “Healthy” charging it doesn’t show 100% but 88% of charge and charging complete, disconnect it an immediate shutdown with no reaction on power button aftewards. So it really looks like there is something faulty with charging part of pcb or the battery itself as I remember that battery was showing around 50% last time I was playing with eq settings yesterday at work.
Ok guys. I've been fairly active in this thread and could not say enough good things about the ES100.... up until now.
I've been very patient with this little device over the last 4 months. I absolutely freaking love this thing until the end of time. This is end game for me just as my IE80's have been end game for the last 6 years of me owning them.
BUT
I have gone through 3 replacement devices, and I'm now on my 4th one and it just died minutes ago. I'm using it as a USB DAC with my IE80's on my PC and I just went to plug my headphones in and it died on me. I get a loud popping and rustling noise through the headphones and it's clearly damaged. Over nothing. It was working GREAT 10 minutes ago as I was watching youtube. I went to go take my plate upstairs, came back down, put my headphones on and POP, it's dead. EarStudio and Amazon have worked with me up until this point (I even bought the SquareTrade warranty for this thing, I was happy to for such an awesome device) however they told me that if this one breaks then I should look elsewhere for a new product, which I'm very close to doing (but don't want to because I love this thing so much).
I've waited so long to post this on this thread because I don't want to talk bad about this product. I'm not doing ANYTHING that a normal consumer would do with it. I'm using it as a USB DAC just as it should be used, and I also use it a couple times a week while I'm at work.
I don't know what to do here. I absolutely LOVE this product, but I can't keep buying more of these at $100 a pop. This is my 4th one. I can't buy another one.
Has anyone else had problems like this? I want this to be the last thing I buy but I'm struggling hard here.
Does it have a pattern when it breaks? Like only on your computer? Maybe due to the voltage on that USB port?
Just watched a detective series and feeling like a detective. Hahahahaha.
