SeeD
- Jan 20, 2007
See my post above, Alpha is located in the Seattle area
Thanks! I appreciate the added response. I figured everyone suggested was abroad.
I sent a note to alpha421.
Mike
Yeah, mine seems toI just checked and my ES100 (running current firmware 2.0.2) stays off when charge is complete. I plugged in the charger, turned off the unit (flashing LED stopped and I observed a steady red circle LED, indicating charging) and left it to fully charge.When it was fully charged the steady red circle changed to steady green and the unit remained off, just like the standard behavior you expected. Is yours doing something different?
You have to ask(comment) for the cable lenght
Well that is strange because while I do have to turn it off after connecting the charger (admittedly odd but not really a problem) the unit does not turn on by itself when changing is completed. Are you using the most current firmware release (2.0.2)? If so I have no explanation as to why our two units would behave differently.
I have a question concerning the ES100:
Every time I charge it, it automatically switches on. This can be quite annoying because then it automatically connects to my phone and computer ... even in times when I don`t want it to. It happened so many times now that I wanted to make a phone call and was wondering why I could not hear a thing (because it was auto connected to the ES100 while charging).
So is there a way to switch the "auto on while charging" off?
There are a few power options but they will probably have undesirable side effects for typical use. The easiest solution is to simply switch the power off after plugging in the charging cable, it only takes a few seconds.
Maybe I'm not understanding your issue, but why not just select "auto power off when charger connected"? If you need to run it when connected, change it back.Thanks for your reply! But hmmmm....still find it annoying (especially because my charging cable is a bit hidden under my table and it gets really fiddly if I also have to switch it off every time I charge it) . I am still wondering why that is? My XB10 and my XDSD don`t do that? What is the benefit of this "auto on" function? Nobody else here finds it annoying?
Maybe somebody of Radsone is reading this? Maybe it could be changed through an update?
Many people like to top off the charge while listening (say when sitting at a desk) on a routine basis. In this case having to constantly go in and out of the app is not acceptable.
I think most users would agree that the power state should not change when charging. The Radsone people have been pretty responsive in adding/changing features in firmware updates and I think they monitor the forum, plus you can provide feedback on their website.
