I pretty much have everything at the default. I use 'sharp rolloff' for the filter (I can't really profess that there's an obvious difference, but that's what I'm using.) As above, I wouldn't expect any difference with things like DCT or oversampling unless you have some problem to solve, which is usually not the case.
Things like crossfeed and EQ are simply matters of personal preference. Experiment with crossfeed (which will crossfeed some signal between right and left which will have an effect on soundstage), some people like the effect and some do not (personally I generally do not use it.) Same with EQ, some see a fault in using it as some purist thing but I've never understood that, I see it as simply a tool an I use it whenever I feel the need, or even just to suit personal preference.. the purpose of listening is for enjoyment after all, not a science experiment, nor is there any requirement to suffer through a poor mastering as some form of personal honor
. I would advise staying away from preset EQ profiles and instead develop your own. Start with flat and if you think that bass seems thin or the high end seems flat or veiled then tweak as necessary,
in small increments, just a little here or there to fix poorly mastered recordings or adjust for weaknesses in the playback system or speaker/transducer. With the SE846 you shouldn't need much.
