ace8888
- Sep 14, 2007
Ace8888,
If you have read posts here on this thread already, you must have an idea what this DDM sound like. Next step is to audition this in person, no other way around. Unless you try them, you can only speculate how will earphones suite your needs.
I personally like DDM and UM3X, as well as e-Q7, but it varies and all depend on the mood I am in and all that goes with it.
DDM are my favorites among Dynamic drivers. I still prefer e-Q7 over all other BA type drivers out there.
P.S. I do not work out but I do walk/jug quite a lot and I have no problem what so ever with the seal. I guess it all depends on the way you wear them and what ear-tips you will be using. I am using comply foam and those work nice for my ears.
If you are in the USA, you can get Radius DDM from ALO audio and in case you do not like them, you can try exchanging for another pair of IEMs, I believe. The person in charge, Ken, is a great dealer.!!
Hope this helps.
http://www.aloaudio.com/store/index.php?main_page=product_info&cPath=2_66_89&products_id=438
Thanks for the info yello131, too bad I don't have to luxury to try these before hand as I currently live outside the states. Will try accessoryjack since they have lower price and great ratings as well. Thanks again.
Ace8888
