Hi guys, I just got myself a QP1R and noticed this peculiar thing:
I have a sandisk ultra 128GB card that I formatted within the player, and then I copied my music files over. The player was able to read all the files. However once the player shuts down and is restarted, it will not recognize the card. If I go to browse file option, it would say Not Found. I need to remove and insert the card back in for the player to read the files again.
I have tried to format the card using FAT32 and exFat but the results are the same. I have another sandisk 128GB card which is showing the same behavior. However, I have a 64GB card and it is behaving ok - player was able to read and load the card after restarting.
Just wondering if any of you have experienced this? Is this likely a faulty player?
Appreciate any insights!
