n05ey
- Feb 24, 2013
That kills resale value if these headphones aren't for you. I got some rubber foam that's used for windows/doors typically and put it in between the holes and now it's comfortable. If the crackling sound is reproduced with different headphones then it should be the track.
The K501 pads are much more comfortable however it seems to bring in the treble. The Lyr should probably fix that issue with the right tubes. The K601 pads probably should do it when they get back in stock since I do recall it bringing out the bass and being extremely comfortable.
yup, it sure does... tho I can't see myself selling these in any foreseeable from here I am searching for a complementary sound unless I can spring into the summit-fi world.
has anyone else tried the aliexpress pads? I bought them due to a sound difference in my original pads and have been using then since Christmas. they seem a little softer hence comfy and don't seem to compromise on the sound to my ears.
