ThurstonX
Haha, if it works why not let the world know
Oh, I'm not shy. Notice how colorfully I did it again
There is one downside though, and that is the headband. These bumps on it are terrible.
I read a lot about it and noticed that other Q701 owners have a similar opinion about it.
After wearing the Q701 for a longer time the bumps actually reshape my head.
I have the Q701 for about a good two weeks now, over 80 hours of listening already.
The sound is fenomenal. As a producer, I really enjoy the crystal clear natural sound they produce.
Soon I will get the Fiio E17 AMP which should make it even better, I will tell my findings once I got it.
I'm actually getting concerned it will stay like this forever.
I don't want to cut the bumps, but is there another way to make it more comfortable ?I
Is there some way to soften them up ?.
Hmm maybe cutting is the best idea after all.
I can't fathom how these bumps got through the design iterations at AKG headquarters.
I'm pretty positive that about 99.9% of all the people who wore an AKG Q701 longer than 4 hours agrees on the fact these bumps are an absolute pest.
Perhaps all the testers had a whole lot of hair.
First post, but I've been lurking head-fi for a while now. I've had the Q701 since the start of December and have been in love ever since. Previously, I only had the UE900.
I too had a problem with the lumps being painful after a few hours of constant use. I drilled out the "Rivets" holding the headband in and replaced the headband with a section of an old leather belt cut to size. Secured it with some thumbscrews from a spare computer case and some nuts.
Besides the off balance feel you get from having the cable connect only on one side, I can hardly feel it while wearing them for long sessions now.
I'm pretty close to pulling the trigger on the Q701, are there any issues with buying AKG's or headphones in general on eBay? I'm asking because Amazon has them for $199 but they seem to be the newer 'made in China' version and eBay still has sellers offering the 'made in Austria' version for the same price. It's also easier to get verification on this subject from eBay sellers than an Amazon vendor. The country of origin is not a huge deal to me but if it's all the same I'd rather have the original made in Austria. I'm just not sure how safe / legit buying on eBay is when it comes to headphones.
Wow the bumps are that bad?
I'm glad i got the made in China version's then, the bumps are so soft now that they almost sit flush with the head band. but if you get the China versions you have to give them a couple of day's to stretch out, cause damn those suckers are tight at first.
