Taowolf51
- Jul 6, 2009
Here is the original Kees Mod post:
http://www.head-fi.org/t/396267/how-bright-is-an-ultrasone-pro-900/
Post 70.
For the sound quality, it brings the bass back a notch, brings out the mids, makes the highs a little rounder (not as metallic), makes it feel a tad more organic, tightens the bass, and overall makes it a little more balanced. The thing that changes it the most is the cotton wool (basically adisposable makeup pad). I would pull it in half (so it is half as thick) so that it doesn't do *too* much to the bass. You should listen to them for awhile, mod it, and listen again. If it is too much, remove some thickness from the makeup pad. Originally I only used the chair gliders (those little felt pucks), but in time, I added the makeup pad as well (making it a bit less than half as thick). Also, be careful with the screws, they can easily be stripped if you unscrew them enough times. Be sure to screw them back in with a decent amount of tightness, you don't want anything to be loose (changes the sound).
