Shure or bust
- Jul 24, 2015
Na from NYC. Hopefully the mic works.
I picked up a pair of psb M4U 2's for $160 on ebay. I highly doubt Oppo pm3 is worth the $250 increase imo. I just bought a master and dynamic boom mic to test out with them. Should arrive soon.
They had bass for africa, but it lacked quality.
I'm going to be honest man, I don't know. If you're looking to buy it, then you don't need to worry. They've def. fixed the issue by now, and even if it does (somehow) come up, the warranty lasts 2 years. I think it's generally a small crack that spreads, at which point most people just send it back to be replaced.
Well, my M4U1 are here! Getting to know each other. Just some initial impressions.
Great isolation and absence of leakage, exactly what I was looking for. My Fiio X5 II DAP runs them easily (High gain, volume level 45-55 out of 120) Clamping force a bit too high but not unconfortable. Soundwise I prefer to let them run for awhile before sauing anything, but there are strong and weak points out of the box. Anyway, much better than B&W P3, my current closed portable HP that will be sent to oblivion. I whish to thank all you head-fiers for your great informatn and help; without you I would not have found these great cans, almost unknown here in Spain.
Good to hear! Looking forward to your impressions after breaking them in. I do highly recommend purchasing an upgraded cable; If you have been reading far enough back you know my gripe with the cheap no-thought pack in cable that is equal in quality to a Dollar-store 3.5mm interconnect. Just make sure one plug is sIim enough or made of a material that you can easily shave a few millimetres off, or drop me a PM and we can arrange for me to make you one.
