... *facepalm*
Practice your Google-fu more. Images are doable here.
... *facepalm*
Did you seriously just quote a post from the late CB3723? *facepalm*
As far as I know the on-ear and over-ear version both share the same driver, so the XL should be driven as easily as the on-ear. They sound different only because of how the cups lay on the ears.
Proof from this video, driver same is exactly the same:
also inner fidelity posted a photo of the driver unit, and it has a small casing behind it, so the "internal" cup shape shouldn't change the sound that much.
Just the different seal on the ear must produce so different bass response, more powerful on the on-ear and more balanced on the over-ear version.
correct me if my suppositions are wrong
The "small casing" behind the driver makes up the main driver chamber, the rest of the cup is the "bass chamber". Another guy compared this kind of setup to speakers and the "bass chamber" being the back wall that reflects bass, I forgot what thread. If the bass ports on the main chamber are very tiny like with HD380, HD280, and HD360, the acoustics in the rest of the cup aren't that important indeed as I've found out through modding, but Urbanite has larger ports, more like HD4x8/4x9. HD400 series is much more affected by the acoustics in the second chamber since the ports are substantially larger versus 380/360/280. Urbanite is probably more dependent on the rest of the cup much like HD4x8/4x9.
I very much prefer the M50x to the urbanites, more portable, more cables, better design (IMO), much better, livelier and more dynamic sound, and plus comfort to me is a lot better
Compared to the urbanite XL (I only heard that one, and its in a direct, side by side comparison), the M50x for sure have more treble which is more detailed and lively, more dynamic bass and more lively mids. With some of the piano sonatas, the XL sounded like a torture chamber
