- Aug 18, 2007
Well, I am only dropping the 64-125Hz band by 3-4db, and boosting the 250-500Hz by 2-3db for about half my music. And, of all my phones, with NO EQ these are the best for classic rock like the ones I listed. I can also try some of my other amps with these. So far I have tried direct out of the iTouch, and Macbook and they were way too bassy. I also have tried them with my Macbook via Lyrix USB DAC amp, and finally CD optical into iBasso D1 then to the DarkVoice 336i. My Meier Headsix might actually be the perfect amp for these DB v3.
I see a couple of small holes in the plastic ring on each side, at the base of the woodie part, those are the holes you recommended plugging? From your previous descriptions, I began to think that your V2's were intentionally ported, while these looked like leftover holes from doing the mods and re-cable.
But, you may be right that Darths are just not my cup of tea. My Proline 2500 feel the same (cozy) as far as fit on my head, and have the right sound but they aren't closed which I needed for bedroom listening. My HD25 sound good but don't have a wide soundstage, and are not the most comfortable. My APS V2 re-cabled Denon D2000 are probably the perfect sounding closed phone for me, but they fit a little too loose so I can't lay down with them.
I think my search for "closed cans that sound transparent like open HD600/650 cans" will likely have to end with the D2000. I can fix my curiosity about the Proline 750 easily, but the Edition 9 will be more of a challenge, especially since I just dropped $400 on an amp for my STAX SR-Lambda.
I could get $400+ for Darths, $300 for triple.fi 10 pro, $120 for my Bose On Ear, $140 for almost new P2 amp , almost $200 for recently modded Xin SuperMacro III with all the switches/rechargables, and $100 for vintage Sony D-5 pcdp = One pair of Edition 9. Hmmmm....
Originally Posted by Towert7 /img/forum/go_quote.gif Hm, sounds like the Darth's are not your cup of tea if you are doing that much EQ'ing, and finding that you have to switch to different EQ's for different songs. I assume you have tried the adhesive putty mod? I would expect that would do most of the EQ'ing you are doing without the need for EQ. You may want to give the HD650 a shot someday, as it sounds like you prefer a sound sig like the HD650 (like myself). |
