This is my first take on Sijosae's iHybrid Nano - in an Altoid Sours tin.
It's not a bad little amp. His suggested 100k trimpot may be too low of a value. I ended up settling on a Philips NE5532 for the opamp. jrc4580 and opa2111 also sounded pretty good.
Sorry, no obligatory glowey picture. The 6111 is barely two dots of red in the dark anyway, and since it's inside the tin i made no effort to illuminate it.
Perfboard is from some one-horse outfit called Measure Explorer. It's very good pcb material and has a masked groundplane.
Also slightly proud of my wallwart hack. $2 thrift store 12vdc 500ma wart, replaced original 470uf cap with a 1000uf cap, 1n4001 diodes with 1n5817, added snubbers (possibly not needed with schotts), and bolted in an LDO 12v regulator.
Regulator is a Sanken SI-3122V. TO-3P formfactor, it's rated at 2 amps with a minimum voltage drop of 1 volt. It's performing very well. Unlike a 7812 or lm317, when it's only asked for 350ma it doesn't get hot enough to require a heatsink. Plus since the legs are fairly far apart, it was very easy to solder the protection diode and input and output caps directly. The package also electrically insulates the bolt that fixes it to the inside of the wallwart.
The datasheet called for "approximately .33uf" of ceramic caps between input and ground to prevent oscillation. I don't have any .33uf ceramics and the .33uf film caps i have are enormous, so i used approximately three .1uf discs. Ugly, but it works.
This amp runs fairly hot. the heatsink on the 7806 gets up to about 65c.
