Post pics of your builds....
Apr 20, 2007 at 7:03 AM Post #1,996 of 9,811
Housed in a shortened Hammond 1455C801 case. Switch-selectable USB power or external power.
Apr 20, 2007 at 10:47 AM Post #1,998 of 9,811
Originally Posted by ~n00beR /img/forum/go_quote.gif
Nice work as ever amb
But how did you do the decals?
Are they engraved, or did you employ another method?
No, nothing fancy. They are simply black-on-clear self-adhesive labels printed on a Brother P-Touch label maker machine. I sprayed a thin coat of matte clear over the labels so they're not shiny, and would better match the Hammond's finish.
Apr 20, 2007 at 5:02 PM Post #2,000 of 9,811
Originally Posted by Walie /img/forum/go_quote.gif
amb: Is there a noticable improvement when the AlienDAC is powered by external power compared to usb power?
Never tried Regulated USB vs External power at the same voltages, but 5.4V from a good external voltage regulator sounds better than 4.7V Regulated USB in my implementations using a simplified TREAD. The difference isn't large, but it's there.
Apr 20, 2007 at 5:52 PM Post #2,001 of 9,811
Real nice casing. I like that you have it set up to switch from USB to external. Makes me want to rerig my dac for that purpose.
Apr 20, 2007 at 6:31 PM Post #2,002 of 9,811
I did some noise floor measurements via RMAA looped back into my M-Audio Firewire Audiophile, and at 16b/44.1k, there is practically no difference between USB power or an external 9V battery (both regulated to a measured 4.77V by the REG101UA onboard). At 16b/48k, however, the battery gives approximately 2dB lower noise floor through most of the audio band. Not a huge difference, and since these are all well below -100dB it's not going to be audible.
One thing I did observe, is that the noise floor is about 6dB worse when the board is uncased. Since I have very little RFI where I did the measurements, I think the extra noise is probably self-induced. Since the PCM2702 has the DAC and the analog output section built-in, and no provision for separate digital and analog grounds or other isolation between the two, there is probably noise crosstalk from the digital section into the analog section. By having the PCB encased in a grounded aluminum extrusion, the amount of radiated noise is partially absorbed.
Apr 20, 2007 at 6:52 PM Post #2,003 of 9,811
As an added incentive to having it cased... I shocked mine to death the other day.
Back to using my onboard sound. Oh well, it's only for gaming anyways.
Apr 20, 2007 at 8:05 PM Post #2,004 of 9,811
So, here is what I build last - oh, I don't even know any more how long it took. I am not very skilled with any of these things so let's say that it took quite a while. It isn't completely finished yet, but I am getting there.
The amp is a Porta Corda USB originally so that part I didn't build. I've got Sir Meier to thank for that. I just made the wooden casing. On the back of the amp I also made a connection for a 24V adapter.
I started out with this:
After that I ended up with this:
And right now I've got this:
The drawing on the top has been burned in there. You might not be able to see it that well on the picture.
I still want to get some kind of power supply in there, but I have no idea how I should get it in there or what kind of things are available. Suggestions are welcome.
Edit: You are going to have to do with a crappy picture of the result until there is a better camera available here.
Apr 20, 2007 at 10:20 PM Post #2,005 of 9,811
[size=medium]Here is my newest....Retro stylee...[/size]
Size: 8.5 inches x 5 inches x 6 inches deep.
Weight: about 15 - 20 lbs.
Contains:
+15v (78/7915) regulated PSU.
Walt Jung's AD823/AD815 based Low Distortion Line Driver.
50k dual step attenuator.
Preamp out jacks (w/optional output caps, via a switch) connected to switching headphone jack (w/out caps).
Switchcraft patchbay TRS jack.
Relay based on/off muting circuit.
Ground loop isolation.
Exterior ground tap.
[size=medium]I found this box at a junk yard, made of 1/2 inch thick aluminium...and went to work...[/size]
[size=medium]How about a tube shield used as a jack shield ????[/size]
[size=medium]Just before final assembly:[/size]
http://i5.photobucket.com/albums/y17...t/DSCN2001.jpg
[size=medium]Front and Back:[/size]
[size=medium]another view:[/size]
http://i5.photobucket.com/albums/y17...t/DSCN2002.jpg
[size=medium]Sounds: neutral, not emphasized in any one area but still very detailed.
I have not compared it to my other Hamps, yet.
Offset around 1.7mv both channels.
Completely silent at full volume.
[/size]
(no, really dude, my pot is better than yours
Apr 21, 2007 at 12:36 AM Post #2,008 of 9,811
Contains:
Holly Cr*p! That is built for 40,000 ft drop!
I was going for simple small case for my Desktop CMoy...
Apr 21, 2007 at 12:42 AM Post #2,009 of 9,811
Dang thats tiny! I love it
Apr 21, 2007 at 12:54 AM Post #2,010 of 9,811
That case is good enough for an aircraft flight/voice data recorder...
