Just got the vinyl 2013 re-issue of the 1994 re-mix of the Bladerunner
soundtrack by Vangelis. For vinyl lovers who are also into sub-bass,
I can recommend this space music type recording. I'm not a big
Vangelis fan but this may be his best with no corny tunes to suffer
through.
I've got that soundtrack in so many shapes and forms (including that heavy red slab you have), it's ridiculous. I agree that much of Vangelis's work is difficult to get through, and this is by far the best of his soundtracks. But don't discount his early work like Spiral, which leans heavily into a Berlin-school sort of sound. Good stuff!
No, the name of the company did escape my memory, arm type not: RB 250 ( or to be precise - the one without spring VTF adjustment that in Rega creates trouble after trouble after trouble...). It ( Audiomods) has MUCH better bearings than the stock RB1000.
http://www.audiomods.co.uk/completearms.html
The only way to improve upon this arm without basically starting from scratch (and increasing the cost beyond reason...) would be a counterweight along these lines:
This style of counterweight is applicable to many other designs, most notable is the one for the otherwise excellent Hadcock unipivot tonearms, which are above royal level PITA to adjust for the azimuth in the first place - AND even more PITA to keep it that way long term. Design from this seller for Hadcock unipivots is both elegant and repeatable - and most important of all, should keep the adjustment over time well. With the usual improvement in sound this type of CW brings : better bass, soundstage, dynamic range, smoother treble - in short, an across the board improvement.
(No affiliation with the seller, I (used to) use DIY CWs of this type for decades).
My wife does not like the mess. The mess is sadly, now gone.
The Cubes, while unconventional, are amazing. I went with a Clarity Cap upgrade and I think the cabs are stacked birch. They disappear. I'm going to play around more with placement and some extreme-toe-in soon.
current setup, so as not to derail too much here but thanks! It's been a lot of work with a patient family!
