arcorob
- Dec 22, 2013
I normally spin the platter up with the last twist of the puck. It helps saving the belt from slipping. And I hardly ever turn the motor off. When I had a Linn I always kept the platter spinning while changing. This is quite easy with the felt mat.
I don't really know why this is (maybe because I keep modding my phonoamp to ever increasing heights), but I keep hearing hum from the motor/belt when I play. If I take off the belt and spin it by hand it's dead quiet. Now that I hear it I keep noticing it. I just can't unhear it.
Hi ,,maybe I missed something but you have the Performance table, a step-up up and then the Jolida. Are you hearing noise at the speakers or at the actual table itself?
IF AT THE SPEAKERS...JD9 ..notorious for having noise unless modded...I think that is your issue. That is why I went with the Phonomena II phono stage. Dead quiet and no need for a step-up. Not sure why you are using a step up anyway. At .4mv, any MC phono stage will easily have enough gain.
Now if you are running the step up to the MC section of the JD9 ..egads...No wonder you hear noise..way to much gain.
SO tell me more...because you should hear nothing at the table..unless your ears is on the platter...
