alvaroenoht
to do this mod, you will have to feed the heater filament in a separate circuit.Back on page 20, there's modification shown, which adds regulators to each tube power supply circuit - https://www.head-fi.org/threads/portable-tube-amp-from-china.626237/post-14530910
That's another thing that I'll probably try with my B4-X.
That sounds like a really interesting project. I asked the Ebay seller who sold my B4-X for a schematic but was told they can't provide one, so if you could draw a schematic for us that'd be extremely useful!
I'll be very interested to watch your progress. Perhaps a blacker background, better dynamics & imaging would result from more stable voltage being fed to those tubes.
Just spitballing here, but would it be very difficult to mod the 3.5mm input to 2.5mm balanced instead, thereby making the amp fully balanced in the truest sense? I previously owned an ALO CDM and found the difference in performance between running it in single-ended & fully balanced modes was enormous, in the latter it really came alive.
I have been working on the schematics during my lunch break. The b4-x is already balanced. the circuit is balanced in the sense that each channel has an independent power supply, preamp stage and the output stage runs two opamps in parallel per channel!, the components selected seem to be of good quality too. I havent check how they grounded the 3.5 but the 2.5jack is just in parallel with the 3.5 so you should be able to listen from both outputs at the same time.
Perhaps if we remove the 3.5 jack and remove the common ground at the output the sound will improve. I am more focused in the power supply part for now since I want to be able to increase battery time.
I noticed the dc jack is directly connected to the battery and I assume that it has a switch that shuts down a relay that cuts down power to the unit when inserted. I dont think is safe to bypass that relay and use it while connected since it doesnt have a bms and that can damage the battery, but an external battery could be used. it has 5 caps in total for smothing the power one shared before the dc to dc converters and 2 after each channel for the -12v and + 12v rails. A further improvement could be to up the voltage to 16 or 18v, but thats basically redoing the whole unit, not worth it imo.
The suggestion of having separate power supplies for the heaters I dont think is good since the heaters only need 6 volts and they dont care about ripple or noise, most heaters in big units use ac.
