Allow me to report on my recent portable amp developments.
A few days ago the Oriolus BA300S arrived and I've been burning it in ever since. After conducting a final listening test today I arrived at the conclusion it is not the answer. I don't know if its because I'm using it with A&K DAPs rather than Sony which I assume its been tuned to match, but the sound is too dark and the soundstage too narrow to match either of my DAPs satisfactorily. The Little Bear B4-X is a far better match and it isn't even close. As a result Operation Little Bear Transformation has been launced, and to that end no time or expense will be spared making it all it can be.
So about two hours ago I retrieved my old soldering iron and brushed off the dust that been collecting for the better part of three years since last using it. As luck would have it I'd built up a small collection of audiophile caps, resistors and such from those DIY days and so was lucky enough to find a number of Elna Silmic II electrolytic capacitors ready to use. For those not versed in DIY, in those days (and perhaps still today?) Silmic II's were commonly regarded as the highest quality electroytic caps available now that Black gates are no longer being made.
The largest caps with through hole leads small enough to fit the B4-X's existing board was a quad of Silmic II 220uF 16v, more than double the capcitance of the Rubycon branded 100uF 25v power supply caps they replaced. Yes they're too large to fit inside the existing case properly and are only in there temporararily because I was eager to hear if they'd make any difference.
Well. Without knowing how much difference is due to the larger values providing a greater reservoir of power storage and how much can be attributed to them being higher-grade components, the change in sound is of a similar magnitude to what I experienced replacing the stock OPAMPs with Burson V5is.
Pardon me for gushing a little but there have been across the board changes. Deeper bass -especially sub bass- was immediately the most notable thing, but the soundstage has also widened and deepend, there is better articulation, and the dynamics are better. I would liken the overall effect to the feeling of upgrading to a significantly more expensive amp, and whereas before I was somewhat on the fence about using the B4-X with my SP1000 & Lunas, feeling like as much was taken away as was added, now there's no question I'm more satisfied with the amp in the chain.
Next I plan to upgrade the resistors, and would also LOVE to upgrade the battery but have not found a good replacement - does anyone know where I can source a 12v (or is it 12.6V?) 2-4000 mAh battery to replace the rather wimpy existing 1000 mAh one? Four hours of playback just isn't enough for an entire evening.
Pardon the quick & dirty photo!
