That sounds like a really interesting project. I asked the Ebay seller who sold my B4-X for a schematic but was told they can't provide one, so if you could draw a schematic for us that'd be extremely useful!
I'll be very interested to watch your progress. Perhaps a blacker background, better dynamics & imaging would result from more stable voltage being fed to those tubes.
Just spitballing here, but would it be very difficult to mod the 3.5mm input to 2.5mm balanced instead, thereby making the amp fully balanced in the truest sense? I previously owned an ALO CDM and found the difference in performance between running it in single-ended & fully balanced modes was enormous, in the latter it really came alive.
I've got a pair of fully balanced amps - iBasso PB2 Solid-State Portable & Loxjie P20 Tube/Hybrid Desktop.
It would be great if the Little Bear B4-X was fully balanced, but modifying it, in the available space, would be a bit tricky.
A.] If you want to be able to take a Balanced Input, and provide a Balanced Output - then you'll need to make these changes:
1.) Add a 2.5mm TRRS Input Jack
2.) Route the L+, L-, R+, R- signals to the tube pre-amplification circuit (bypassing the phase-splitter that would be needed for [
B.])
3.) Add 2 more tubes for Balanced pre-amplification of L+, L-, R+, R-
4.) Reconfigure the current op-amps to be 4 separate buffers (instead of phase-splitters) to drive the Balanced Output
B.] If you want to be able to take a Single-Ended Input, and provide a Balanced Output - then you'll need to make these changes:
1.) Add a phase-splitter at the Input (which is what the current op-amps are doing for the Output) to create the L+, L-, R+, R- signals
2.) Add 2 more tubes for the Balanced pre-amplification of L+, L-, R+, R-
3.) Reconfigure the current op-amps to be 4 separate buffers (instead of phase-splitters) to drive the Balanced Output
So the design concepts are fairly simple, but trying to add additional op-amps (w/support circuitry), and tubes (plus voltage regulators for the tubes), while still leaving space to do op-amp rolling - inside the current B4-X case - would probably require creating a completely new main circuit board, along with daughter-boards, so everything fits.
