Do you have any credible scientific research or studies which verify that any frequencies travel through a cable the way you describe? Also, is there any measurements via CSD waterfall, frequency response chart, or any other valid measurement with controls in place, and that are repeatable, which demonstrate cables make a significant or measurable difference in sound quality?
You can't possibly be serious.
The skin effect has been known for 135 years. Here is the entry in Wikipedia, the source of all, often accurate information:
https://en.wikipedia.org/wiki/Skin_effect
Sheer speculation on my part: the electrical signal at the skin "sees" less resistance. The deeper running currents, seeing more resistance may suffer a lowering of freq response and/or speed of transmission. This may result in a brighter sound due to inhibited lower frequency transmission, and maybe even slower transmission of the lower frequencies. (Think of how miniscule timing issues from digital jitter affect sound). (I'm having fun, btw).
Coating the wire with a higher resistance metal may tamp down the high freq signals to be more consistent with the lower freq. signals, resulting in a less discombobulated sound.
Like I said, sheer speculation!
Commentary at Belden about skin effect, basically saying it has so little effect in audio frequencies we can ignore it.
https://www.belden.com/blog/broadcast/understanding-skin-effect-and-frequency
There’s no way you can cram enough metal into 26AWG wires to be worth $1K, no matter what metal you’re talking about. Assuming that electrical transmission is your only concern, anyway. Some of these cables do look fantastic, I have to admit. But since I listen by myself, for myself, I’m not all that concerned with looking dope.
The spot price of palladium today is $2,230.30 an ounce.
Thought experiment: figure out the price of the raw materials in a car, house, coffin, flat screen TV, Single Malt Scotch Whisky. Try to buy any of those for less than 5 times the price of the raw materials.
Opposing information: a quick Google search on "palladium coated copper wire" found 1,400,000 hits.
To increase the validity of posting on this thead, I propose we all read every entry before further commenting.
Okay, I'll cheat: the price of palladium coated etc. is 2.5 to 3 times higher that uncoated wire.
Closing comments: science and engineering are very valuable where high confidence in what we are doing has high benefits. Such as tech that might explode or crash, or new drugs that can cure or kill. On the other hand, only a tiny, make that a teensy bit of phenomena has been scientifically researched. Most decisions human make are by rule
or [edit: of] thumb, wisdom guided by experience, things that have passed the test of time.
If we require hard scientific proof
(are [edit] some of the demanders will only move the goal line if offered proof) for every new bit of tech or exercise or behavior or a new tasty food recipe before adopting it, would we still be be using, Morse code?, oil lamps? land line dial phones?
There are lies, lies, and
statisctics heuristics.
