violencer
- May 27, 2014
I like Pioneer design more, but Onkyo should sound better, right?
Thanks, I see it now. I would be wary of importing from Japan, though, because of warranty concerns. But it is tempting. So it looks like, for whatever reason, the Pioneer displays album art during playback, but the Onkyo does not. How bizarre. Can anyone attest to whether the Pioneer has folder browsing in its stock player?
getting about 14 at the moment.Has anyone tested the battery life yet? Is it 10 or 16 hrs of music play per charge?
I havent do a full marathon test.. but it is alot better than Zx1.
Yes it able to browse folder with its stock player. Its UI is more interactive than Sony ZX-1 .
i like the UI . very easy to go setting should u need to make any changes. Onkyo cost more might as well use the extra cash for a better amp. jus my opnion.
So as far as I got it right, you're happy with the player. So you are satisfied with the UI, guess it's fast, responsive and intuitive? How about the sound, could you tell us more impressions do you or did you own other DAPs in the past and could make some comparisons?
I am also deciding between the Onkyo and the Pioneer. I have to say that I am puzzled that the UI is that different? Folder browsing not possible with the Onkyo and so on....
Really waiting for some measurements of the Pioneer and some comparisons between the Onkyo and the Pioneer in SE mode.
Post #180 has a link to some measurements
Yeah I am happy with the player. I own a A15, ZX1 and Fiio X1. As for sound quality ,clarity, staging , imaging is way better than ZX1 , except for low frequency , not as punchy as ZX1. But I feel that 100R bass is cleaner sort of SQ Bass. I believe onkyo will sound thicker due to dual Dac? As for folder browsing issue, I believe it the same as case Sony, need to format the SD using the player. Then the folder problem will be solved else u will see all song not in the folder.
