eeagle
So I am having a bit of an issue with my Pioneer DAP, the headphone connection does not "click" or connect very well, I have a couple of headphones that will pop out partially if I move the cable around too much. Is there a fix to this or would I probably have to send it off to pioneer to repair?
Thanks,
James
I have several headphones with larger diameter 3.5mm jacks that contact the bumper and make the connection unreliable or just plain won't fit at all.
One can either use a screwdriver to remove the bumper. or use a small adapter cable to interface those HPs.
Some commercially available USB connectors may not fit and will require a similar solution.
Not sure what that bumper is all about?
