kevindiu
- Apr 8, 2014
So it appears my XDP -300R has suffered the port movement issue. I noticed very slight play on the 3.5mm port about a month ago and emailed Pioneer who said a small amount was acceptable. However I've just fitted a balanced jack and when I've put it in the 2.5mm port the degree of movement is more than I'm comfortable with. I've also noticed the ports don't sit centred to the casing:
I've emailed Pioneer to see what they suggest. Having purchased this on Amazon.JP and living in the UK do you think this will cause issues? I f'ing hope not!
I and my friends just place UV glue around the headphone port to fix the position of the headphone port. Hope it helps.
