Pioneer XDP-300R | Twin DAC ES9018K2M | Balanced Out | Android | MQA | 2x MicroSD | WiFi | AptX
Jan 20, 2017 at 10:31 AM Post #451 of 2,535
Forgot I had a pair of HE400S (lol). Tried those out--balanced is definitely adequate with power to drive them. I then switched back to my W5000 because I can't get enough of female vocals on them. :)
Jan 20, 2017 at 10:33 AM Post #452 of 2,535
Anyone know at what resistance is the power output indicated in the specs sheet? (75w+75w unbalanced & 150w+150w balanced)
Their data sheet shows the rated power level is the same for all loads, so who knows....
XDP-300R DIGITAL AUDIO PLAYER AUDIO FEATURES:
•Twin ESS SABRE DAC “ES9018K2M”
•Dual Headphone AMP “SABRE 9601K”
•Playable Audio Format: MQA / DSD / DSF / DSD-IFF / FLAC / ALAC / WAV / AIFF / Ogg-Vorbis / MP3 / AAC
•Sampling rate and bits: - 11.2MHz/ 5.6MHz/ 2.8MHz / 1 bit - 44.1k/ 48k/ 88.2k/ 96k/ 176.4k/ 192k/ 352.8k/ 384k - 16bit/ 24bit (32bit float/integer can be played downconvert to 24 bit)
•Supported Playlist: M3U/ PLS/ WPL
Output: 75 mW + 75 mW (Unbalanced: 16 - 300 Ω) 150 mW + 150 mW (Balanced: 32 - 600 Ω)
•Total Harmonic Distortion: Less than 0.006 %
•S/N Ratio: 115 dB over
•Frequency Response: 20 Hz ~ 80,000 Hz
•Gain: Low / Normal / High
•Two types of balanced drive via 2.5 mm (4 pole) output - BTL Drive, for increased power - „ACG“ (active control gnd), stability oriented, increased
 S/N ratio, larger spatial dimensionality and clean sound. Greater delineation for lower frequencies in Hi-Res Audio, overall strong and tight sound
Jan 20, 2017 at 11:44 AM Post #453 of 2,535
To confuse things more, the data sheet for the DP-X1 (with the same amp as the 300R) is rated with a 32 ohm load.
Model number DP-X1
OS Android 5.1.1
Display 4.7 inch/11.94 cm (1280 x 720) capaciti ve touch screen
Internal memory 32GB (including system area)
Expansion memory MicroSD (SDXC) slot x2 (200GB Max per slot)
Wi-Fi 802.11a/b/g/n/ac (Wi-Fi Direct/WPS)
Bluetooth®Profi les: A2DP/AVRCP/HSP/OPP/HID/PAN Codecs: SBC/aptX
Supported audio formats DSD (DSF/DSDIFF) /FLAC/ALAC/WAV/AIFF/Ogg-Vorbis/MP3/AAC/MQA (via free update)
Sampling Frequency and bit rate 44.1 kHz/48 kHz/88.2 kHz/96 kHz/176.4 kHz/192 kHz/352.8 kHz/384 kHz 16 bit/24 bit
(32 bit fl oat/integer will convert to 24 bit) 2.8 MHz/5.6 MHz/11.2 MHz (1 bit) PCM conversion
Supported playlist formats M3U/PLS/WPL
Supported video formats H.263/H.264 AVC/H.265 HEVC/MPEG-4 SP/VP8/VP9
Supported picture formats JPEG/GIF/PNG/BMP/WebP
Max. output power 75 mW + 75 mW (Unbalanced/ 32 Ω) 150 mW + 150 mW (Balanced/ 32 Ω)
Jan 20, 2017 at 8:07 PM Post #454 of 2,535
My 300R just arrived from Amazon. So far so good, but I can't get the micro sd card to mount. The player doesn't recognize anything on the card. When I put the card back in my AK100II, it comes up fine. The card is a Sandisk 128gb and formatted with fat32. Any ideas?
Jan 20, 2017 at 11:13 PM Post #455 of 2,535
SDXC specs call for exFAT, not FAT32.  No idea if that's your problem though.
Jan 20, 2017 at 11:48 PM Post #456 of 2,535
I figured it out. It was all my fault. The card was actually formatted in NTFS, not FAT32. I formatted in FAT32 and it worked fine. First impressions are very good. Definitely has more power than the AK100II. Drives my SE846's with authority unbalanced. Should really dominate them balanced. One thing I don't quite understand is all of the complaints about the equalizer being useless and non-functional. The equalizer on my unit works flawlessly. I have very precise control over all the bands +/- 10dB. I am actually shocked at how good it works. Not very fat-finger friendly though.
Jan 21, 2017 at 1:45 AM Post #457 of 2,535
Hello Everyone. New to forum. First of all thanks to OP for sharing the Amazon deal. I got mine from Amazm.co.jp last week via dhl. First ever high end player. Been playing win it using Shure 440 and Beyer DT 880 600ohm. It is able to drive the DT to a reasonably loud volume using high gain setting, which was a nice surprise. The sound quality is phenomenal. Good Instrument separation and nice sound stage very noticable . Rediscovering my music collection. Equalizer is not bad once you figure out. Don't have any balanced headphones yet. Will be looking to buy a pair of HD600 with balanced cables soon. Will post more soon. Cheers.
Sent from my SM-N920C using Tapatalk
Jan 21, 2017 at 5:29 AM Post #458 of 2,535
Agree with you. Played a bit with the EQ last night and I can definitely hear a difference. Pull the first couple of sliders down and the bass is gone, so I quickly put them back up
Jan 21, 2017 at 5:39 AM Post #459 of 2,535
The battery in stand alone mode is amazing. I had 4% left. I activated stand alone mode and after 30 mins. YOU WON'T BELIEVE WHAT HAPPENED NEXT. 3% left
Jan 21, 2017 at 4:04 PM Post #461 of 2,535
  Hmm, what does Standalone mode actually do? Disable all of the networking and connection functionality? Anything else?
Yes and screen as well. Will only come back to 'normal' mode after pushing the power button.
Jan 21, 2017 at 4:23 PM Post #463 of 2,535
It should minimize electric interference for an even better sound quality
 and extend battery life as well, but you will miss out on the eye candy like the cover view and the spectrum analyzer.
Jan 21, 2017 at 11:25 PM Post #464 of 2,535
Coming from the Benjie S5 all I can is say is WOW. Really love how polished the android UI/UX is. Are you guys sticking to the default player?
Need to get a tempered glass protector for this bad boy.
