SnookerDJ
- Dec 22, 2016
No. It plays the same as 'ACG' but the player is defaulted to 'balanced'.And before that your player is mute when plugging something into the 2,5mm port?
I'm dumbfounded everytime i play with the settings on the 300r. But even more so with this! Changing the lock range introduced such a big change to the over all enjoyability especially with this set up, 300r+zeus xiv (on low 1) i may not have to sell my r6 for the qp1r now lol. Idk why but theres no more hiss when i changed the lock range, before going past low 2 was never an option with me due to the hissing problem now its gone (?)
I have no idea, but it confuses me too, so I left it alone. I will have a play with it later.
BTW "on Low 1" do you mean one step from the LHS. so wide+1?
I just found out that the lock range regulates the amoun of jitter introduced to your files so basically reducing the range to normal or even narrow reduces the jitters and makes the song sound much more refined ang clean. And by low 1 i meant the gain setting . Oh BTW what do you mean by LHS?
Also I think these settings only work in the built-in music app and I usually use USB Audio Player Pro.
It's not really a 300r related question but seeing how many of you use UAPP, here it goes:
Is it just me not finding an option hidden in the app's menu, or does it really not have a 'resume' feature?
Every time I power up my player the app seem to reset...really annoying.
Would appreciate some help with this as this is the main reason keeping me from using it over the default player.
Thanks
UAPP remembers the current song and position when you exit using the back button or Exit entry in the slide-out menu
Ah thank you very much!
Is it possible for this feature to also work on 'power off' in a future update maybe?
It already does, as long as you exit before powering off, I would suggest you always do this especially if you want the player to resume playback when its powered on again.
