Feb 2, 2017 at 6:54 PM Post #22,713 of 38,979
Feb 3, 2017 at 4:25 AM Post #22,716 of 38,979
The Brise  Audio cables are well constructed. But there are some aesthetic issues I have a few concerns about, namely their somewhat stiff and tend to be tangly. I would hang them straight overnight (not every night though) to keep them straight again. The Pentaconn connection is long however having said that the new Brise cables use Rhodium plugs which are shorter (I think these are limited edition?). Another issue is where the Y splits off which is much earlier...a little excessive for my tastes.
However sonically, I don't have any complaints about them. I only have the UPG001 which is quite decent. I'd dream of their Murakumo which is a super high end cable that I'll never be able to afford - but sonically was probably the best cable I personally had heard. (note, I've not heard of other super high end cables though). So for now, their UPG001 will have to do for me.
Thanks for the info - yeah the aesthetics look a little unrefined in some areas for my preferences. Cheers
Feb 3, 2017 at 10:30 AM Post #22,719 of 38,979
Are they Spiral Dot tips you use on your 1Plus2.2 mate?
I'm using them atm, there's also a tip I can get on eBay Skull Candy branded (serious) that sounds quite good.
They even have the little Skully Candy skull embedded on them.
Feb 3, 2017 at 5:07 PM Post #22,721 of 38,979
Been doing the cable swap thang but nothing has really sounding better or that different than the stocker
Feb 3, 2017 at 5:28 PM Post #22,722 of 38,979
Hi H20! Can you link me those tips please?
