Nov 25, 2015 at 9:49 AM Post #18,423 of 37,686
The Cayin C5 does not output a balanced signal.
Rzepa found this information too, from this review: http://www.head-fi.org/t/738766/review-cayin-c5-a-new-reference-in-portable-amplifiers
Nov 25, 2015 at 9:54 AM Post #18,424 of 37,686
Havi B3Pro1 and Fiio X7
60+USD iem with a 600+USD DAP= Total bliss :)
PS: X7 is a World Review tour unit.
Nov 25, 2015 at 11:06 AM Post #18,428 of 37,686
its 3.5mm does se and balanced output.
i think the reviewer meant that it can "drive" the re-600/400b - even if the pin configuration being used by the iem is TRRS configuration as compared to a normal TRS.
i was checking the manufacturer website - http://en.cayin.cn/product_view.asp?id=792 and it doesn't say anything about balanced output. if it does, they should have indicated output levels for each SE and Balanced
Nov 25, 2015 at 11:12 AM Post #18,429 of 37,686
Beautiful, I just got a x3ii. But I can't justify a $600 DAP purchase.
Nov 25, 2015 at 11:22 AM Post #18,430 of 37,686
is your rig protected by styrofoam? thats ingenious!
Thanks!
No it's PLA. It's the cheapest material on Printerhubs. It was actually supposed to be prototype to see if all my measurements and allowances for the DX90 and the 4400mAh x-large battery were correct but it fitted so perfectly that I just glued the cardreader to the back and called it a day xD
Nov 25, 2015 at 11:26 AM Post #18,431 of 37,686
yes i get it but isnt it wierd to write it since c5 will drive anything? dint have to specifically re600 and re400? also he did specifically mention trrs?
Anyway. will try to get my hands on one to try. Really keen.
Nov 25, 2015 at 11:56 AM Post #18,432 of 37,686
i believe i have the answer, since both are 3.5mm, L- and R- would contact the same area for ground as with a normal SE plug
so i'm pretty sure it doesn't output balanced
Nov 25, 2015 at 12:59 PM Post #18,433 of 37,686
