Pictures Of Your High End System II (Same Rules Apply)
- Thread starter Greed
shaizada
Woah!! The V12! Incredible amp!
Funny you mention the V12 I was using that first and sold it in a weak moment! The one in the picture you see is the V20...more appropriately suited to that system.
I miss my V12....I'll pick one up one day. Right now, I have no where to hook it up....it will just sit around which is simply a crime!
My V12:
PAM005
- Apr 29, 2013
It's getting even more impressive !! Al the best for 2017!
Regards,
Harald
Regards,
Harald
PAM005
- Apr 29, 2013
It's getting even more impressive !! All the best for 2017!
Regards,
Harald
Regards,
Harald
Finally got a set up worthy of this thread...
Magnepan 3.7i, MiniDSP DDRC22-D, Parasound Halo A21, Peachtree Grand Pre X1, Project Debut Carbon, SVS Ultra SB 13
What software are you running?
JackDiesel
- Jul 29, 2013
Looks like JRiver with a skin.
I am a bit "frugal" and was wondering if there is a way I can use my Android (Galaxy S6) as a remote, as it is also connected to my system.
Thanks
Thanks
Audio Addict
- Aug 5, 2001
Thanks
JRivers has an app called GIZMO you could check.into on Google Play.
If you search for JRivers, there are a couple of other paid apps for JRiver.
RCBinTN
Thanks All for the great pictures! Some really nice equipment out there. Makes my little GMB/BHA-1 rig look pale in comparison.
Enjoy your music!
RCB
Enjoy your music!
RCB
rrahman
- Nov 21, 2009
mulder01
- Jan 13, 2012
Someone needs to start making these omega shaped stands in a long multi-headphone length and so you can buy one like a metre long or something. So many head fi-ers have a collection and a different stand for each one...
Nice set of cans btw
astrostar59
BannedMember of the Trade: Aries Cerat Espana, Auriculares High-EndAKA Headstage, headphoneweekend
Nice thread guys.
My speaker and HP combo system.
Layout minus the speaker plinths.
Zingali Client Name 1.2
Rednet 3 AOIP and Mac Mini with 12V DC LPS
DIY KGSShv Carbon and Stax 009s
Audio Note DAC 5 and Passive Pre-amplifier sat on top.
SA-103 Class A Power Amplifier
Custom Marble speaker plinths
Inside the KGSShv Carbon
Inside the DAC 5
P10 Power Regenerator
It is a slightly crazy near field system as you can see. I was worried before the speakers landed if it would work. But luckily the throw on the horn speakers is so wide it is fine. A concrete floor helps to avoid bass issues, it goes deep and is fast. Use is 70% speakers, 30% Stax phones approx.
A hotch potch journey to get to this stage. I built some DAC kits, bought and sold new or used gear, and had 3 DIY Stat amps build (all excellent). I have an AMR DAC and the 007As for a second system. I think the thing I have learn along the way is EVERYTHING affects the sound you can get, DAC (not as obvious), Amp (obvious), Speakers (obvious), Cables (hard to believe), quality of mains supply (hard to believe) quality of power supply to music server (not obvious), getting rid of USB (not obvious). Then caps changing and tube rolling the DAC. Right now it sounds just right for me, so very happy.
Inside the DAC 5
sterling1
- Oct 23, 2010
Here's what I enjoy with what leisure time I've got. I mostly listen to jazz, like Bill Evans and Scott Hamilton downloads to iTunes. From the laptop I use either a hard connection to pre/pro via Creative Sound Blaster X-FI HD, or Wi-Fi via Airport Express. Most of the components in my system are 16 to about 37 years old. I've posted my system before but the pics were pretty small. The only upgrade I'd like to have is a multi-channel SACD player. I have a SACD player but it was made before there was a multi channel SACD concept.
MLGrado
I see DAT. That's interesting. I was looking at DAT player/recorders this week, thinking about buying one just for the hell of it. err, hopefully more like the fun of it.
I was trying to find one that was more than 16bit 48khz, though. I saw where Pioneer made one that went to 16 bit 96khz, and there was an HHS model (not sure what that stands for) that did 24bit 96khz.
But those seem to be non-existent in the current second hand (probably more like third, fourth and fifth hand) market.
