Feb 25, 2013 at 11:38 PM Post #526 of 1,072
I tried the radians kit also, but not with the philips headphones (I tried the MP 8320).  The kit from the earplug store comes with a foam plug that you put in your ear and a syringe to inject the silicon into your ear.  With this, you get a tip that goes deep into the canal.  With the radians kit, you can't always be sure that the earphone is perfectly aimed at your ear canal.  This is the problem I kept having.  By using the casting/mold method, I drilled a hole and used the heatshrink to make sure the earphone was pointed directly at my ear canal.
Feb 26, 2013 at 12:29 AM Post #527 of 1,072
Anyone have sansa clip zip rockboxed eq config equal to joe postpofit eq settings? Please share...
This earphone was good with default eq, but the cable is sucks...
Mar 1, 2013 at 12:30 AM Post #528 of 1,072
For those who are interested in getting these, here are a list of places and prices I've found these:
CVS (B&M and online): $15
Office Max (B&M and online): $15
Target (B&M only): $15
TJ Maxx (B&M only, only some locations): $7
I got mine at Office Max when I had a $5 off coupon because the closest TJ Maxx didn't have them.  I was in a different TJ Maxx the other day and saw them for $7.  Almost bought a second pair!
Mar 1, 2013 at 3:57 PM Post #529 of 1,072
I got 2 pairs for $6.95 each shipped on EBay last week. Fast shipping too.
http://www.ebay.com/itm/221096693722?var=520103920613&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Mar 3, 2013 at 11:06 AM Post #531 of 1,072
Did any of you ever try the Philips SHS8000/100?
I have these and I think they are pretty good. As you can see on my signature, I have a Sennheiser HD555, and while the Sennheiser is better (more detailed across the whole range, more neutral), they are definitely not ~10x better than the SHS8000 as the price would imply. Heck, I'd have a hard time saying they are 3x better. (I know, these are completely arbitrary units, but you get the idea
Now my father wants some cheap in-ears, and I'm considering getting him these SHE3570/80/90. Can anyone compare them against the SHS8000/100?
Mar 4, 2013 at 5:22 AM Post #532 of 1,072
I have the SHE8005 (mic'd version of 8000 I think?) and don't think they are anything special. More bloated midbass than 35xx
Mar 4, 2013 at 12:18 PM Post #533 of 1,072
No, I said SHS8000, they are completely different.
This mini-review pretty much nails it...
EDIT:
So, I tried the SHE3500 today (black with blue tips, in case you're wondering). I didn't test extensively, though I did some equalization by ear (and it turned out pretty similar to your Android EQ - which is a good sign I guess, I wasn't aiming for it at all).
It sounded okay, but I honestly think my SHS8000 is better. I thought the SHE3500 sounded a bit harsh and sibilant, especially without EQ (but then again, I'm usually very sensible to harsh treble). The SHS8000 sounds closer to my reference (HD555) out of the box, and I can get it even closer with EQ.
I'm not a huge believer of burn-in but maybe, just maybe, that's the reason the SHE3500 sounded harsh... If my opinion changes in the future, I'll report back.
I mean, I guess it's good for a $10 IEM, but I didn't find it as impressive as some of you do, sadly (I really really wanted to)...
Mar 11, 2013 at 2:01 PM Post #534 of 1,072
EDIT: So, I tried the SHE3500 today (black with blue tips, in case you're wondering). I didn't test extensively, though I did some equalization by ear (and it turned out pretty similar to your Android EQ - which is a good sign I guess, I wasn't aiming for it at all).
Sorry to seem pedantic - but you wrote about the Philips SHE3500 - when this thread is about the SHE3580 -
are you sure they are the same? - they do look very, very similar in pictures -
but by doing a bit of googling I found the pdf leaflets (links given) for both:
Philips SHE3580
http://download.p4c.philips.com/files/s/she3580_28/she3580_28_pss_aen.pdf
Sound
• Frequency response: 12 - 23 500 Hz
•Impedance: 16 ohm
• Maximum power input: 50 mW
• Sensitivity: 102 dB
•Type: Dynamic
Philips SHE3500
http://download.p4c.philips.com/files/s/she3500bl_00/she3500bl_00_pss_eng.pdf
Sound
•Impedance: 16 ohm
• Sensitivity: 100 dB
•Type: Dynamic
• Frequency response: 12 - 22,500 Hz
It seems the specs say they are different both in frequency response, and sensitivity -
the two areas that do make significant and noticeable sonic differences.
Vincent
Mar 12, 2013 at 10:03 AM Post #535 of 1,072
I don't know, from what I gathered here the whole 35xx series was supposed to sound the same.
So maybe that's the reason... (though I really doubt they sound that different)
Mar 12, 2013 at 1:07 PM Post #536 of 1,072
Really?
The spec's of the SHE3800 actually are different from those of the SHE3580 -
Frequency response: 12 - 22,500 Hz (SHE3500) vs 12 - 23 500 Hz (SHE3580)
Sensitivity: 100 dB (SHE3500) vs 102 dB (SHE3580)
so they ARE different IEMs.
Do you have a pair of SHE3580 to compare, please?
Thanks,
Vincent
Mar 15, 2013 at 11:00 AM Post #539 of 1,072
Having trawled though this thread and forum in general, I would say yes. From what I have gathered, the SHE3590 is the sucessor to the now discontinued (?) SHE3580. The difference between them is only cosmetic, with the newer SHE3590 coming in more colors.
Sound-wise - they are same
