a44100Hz
- Dec 17, 2015
Yeah, these cans aren't bright to my ear. And you can have sensitivity to certain frequencies from hearing loss. https://en.wikipedia.org/wiki/Hyperacusis
They're quite firm pads, but nowhere near to cause discomfort (at least for my noggin). Also these cans are far from bright.. This is one of the main criteria for me, as I hate bright cans. LCD-2F was brighter, to be honest. Almost a bit shouty in the upper midrange. X2 is better balanced, IMO.
Thanks! Is the meter I linked also good to use? Would prefer to get a closer result and it's only $18.
Better balanced? As I've mentioned before, my number 1's are LCD-2.1's. They have way more mids full stop than these. The Audeze's are closer to HD600/650, Spirit Pro etc. in that regard. To my ears, that's a "balanced" amount of mids - X2's are V-shaped. I guess that's one person's perception of balanced. But it's not the neutral kind of amount imo.
To each their own.
X2 are not V-shaped.
Also I specifically mentioned LCD-2 Fazor. They're balanced differently to LCD-2.1. To my ears X2 is balanced better than LCD-2F.
What would you call it then - bass boosted with peaks & valleys in the highs? Maybe that second valley from a real V is missing... Just bass boosted and warm?
I haven't heard the Fazor-models, yeah.
Hyperacusis (also spelled hyperacousis) is a health condition characterized by an increased sensitivity to certain frequency and volume ranges of sound (a collapsed tolerance to usual environmental sound). A person with severe hyperacusis has difficulty tolerating everyday sounds, some of which may seem unpleasantly or painfully loud to that person but not to others.
In cochlear hyperacusis (the most common form of hyperacusis), the symptoms are ear pain, annoyance, and general intolerance to any sounds that most people don't notice or consider unpleasant. Crying spells or panic attacks may result from cochlear hyperacusis. As many as 86% of people with hyperacusis also have tinnitus.[2][4]
In vestibular hyperacusis, the person may experience feelings of dizziness, nausea, or a loss of balance when sounds of certain pitches are present. For instance, people with vestibular hyperacusis may feel like they are falling and as a result involuntarily grimace and clutch for something to brace themselves with. The degree to which a person is affected depends not only on the overall severity of that person's symptoms but also on whether the person can detect sounds in that frequency range at the volume in question, as well as on the person's preexisting muscle tone and severity of startle response.
Anxiety, stress, and/or phonophobia may be present in both types of hyperacusis. Someone with either form of hyperacusis may develop avoidant behavior in order to try to avoid a stressful sound situation or to avoid embarrassing themselves in a social situation that might involve noise.
A person with hyperacusis might be startled by very low sound levels. Everyday sounds like shutting doors, ringing phones, television, running water, ticking clocks, chewing gum, cooking, normal conversation, eating, dishes, and other sounds will hurt his/her ears.
The most common cause of hyperacusis is overexposure to excessively high decibel levels (or sound pressure levels).[5] Some come down with hyperacusis suddenly by firing a gun, having an airbag deploy in their car, experiencing any extremely loud sound, taking ear sensitizing drugs, Lyme disease, Ménière's disease, TMD/TMJ (Temporomandibular joint disorder), head injury, or surgery.
Just mind the volume levels, folks... Most of the people listen at FAR higher levels than necessary. And then start suffering from all sorts of issues...
LCD-2F is a bit more neutral overall, but the upper midrange peaks make them a bit shouty on higher volume levels and less comfortable for prolonged listening.
Just mind the volume levels, folks... Most people listen at FAR higher levels than necessary (for years). And then start suffering from all sorts of issues...
Just have to give time for a brain to adapt to the lower listening levels. You will start noticing subtleties in sound and save the hearing.
