richbass
- Sep 20, 2009
Hey Baycode, How does it compare to DT150 ?
DT150 (closed back HP, 250 ohm) vs X2 (open back HP, 30 ohm):
They do have a good fight in my possession. I can get near-equally good pleasure from both of them. So what are the differences?
DT150 bass section is slightly tighter (only very slightly). But as being a closed headphone one can predict this...
Sub bass is slightly tilted on DT150 compared to other frequencies. But this doesn't mean that DT150 shows this character on every song or every passage -only if the recording calls for it. On the other hand X2 bass section generally have more body and surprisingly -slightly- more detail (after 100 h burn-in). X2 also shows the bass with body if the recording calls for it (one of a good sign for a good HP for me).
Highs are very competitive for both. My general feeling is that X2 delivers slightly smoother highs. On some recording passages, and if the sound level is high, both of these headphones "may" show some slightly peaky highs (grittiness is better term). But I think this is not the fault of the headphones (both DT150 and X2). Its the nature of the recording and listening level -IMO-. But highs do never made fatigue for me (for both HP's)...
Mids are close in quantity (If you swap each HP, at first you start to think that the mids sound slightly distant on X2. But after some seconds brain makes some adjustments (psychoacoustics) and the mids are excellent after that adjustment period for X2).
Intimacy is slightly better for X2. You just sank in to music and never want to take the HP out of your head!
X2 is slightly warmer than DT150 in general, where DT150 is also slightly warmer compared to neutral HP's. So, for me X2 is a warm HP.
Sound-stage is definitely wider on X2, where depth and height are near equal with DT150. On the other hand DT150 sound-stage width is not as wide but its not compressed like some of the closed back headphones as well. I like the sound-stage on X2 better. This is only because soundstage width is wider on them (I like my soundstage -width, height, depth- to be near equal and very wide).
Imaging is near equal for both. They are both excellent on this department.
Layering is better on X2. I really like this technicality of X2. IMO its one of its biggest strengths (but less people appreciate this character, I don't know why). Also X2 sounds more airier (one can predict this because X2 is open backed HP).
Clarity is very very good for both. Sometimes I feel DT150 takes the lead, sometimes I think X2 is better. You know what I mean. If two headphones are very close to being excellent it becomes very hard to put one of them on the front...
For comfort all I can say that X2 is the most comfortable HP I have ever put on my head and ears. Although DT150 can not be classified as uncomfortable -if I have to compare the both- X2 takes the lead.
If I speak only for my full sized HP's, generally I prefer to listen to the X2. It consumes my 70% head time. Other 30% is consumed by other HP's and DT150 takes that lead inside that 30% (at the period though, this may change in future, dunno).
A side note: If you prefer more neutral sound, DT150 is slightly better from "this" perspective...
>Also if you need more isolation and don't want sound leakage than DT150 have to take the lead...
For these comparisons I have used:
Lenovo Netbook -> GO720 -> HP's
or Lenovo Netbook -> GO720 -> DV 336SE (front Psvane CV181 TII Classic tube, rear Zaerix or RCA Military tube) -> HP's
or iPod Touch 4th Gen Lineout -> DV336SE (front Psvane CV181 TII Classic tube, rear Zaerix or RCA Military tube) -> HP's
Note: GO720 with latest firmware 1V5 and driver.
Thank you so much man ! How would the Valhalla 2 pair with DT150 ? Better than DV336SE ?
