sajunky
Please make sure to include a Nobsound 8xTDA1387 DAC/HPA.
bro....sincerly....can you not ''spam'' all my threads it begins to be invasive really....this thread isn't even active. I come back and well...depressing a little.
lol yeah, i think its just the pic that take too much place lol apart from this i would be ok....anyway, im no boss here...Well, you started a convo about them, I tried my best to keep em going...![]()
im more a fan of amping section of XD05+ than DAC, and well, even amp isnt very clean and go higher and higher in THD when we crank the volume...
whats you best amp-dac find under 200$, like...something that sincerly puzzle your mind about price value????
I also have one of this model since 2019 and likeit. I m not a very HiFi fan but like good audio. used mailny for my TV audio and the digital TV decoder with a bit trebly audio Useful to check the broadacsters and listen to nice music programs A Samsung TV and AKG 81DJ or 77 are usedI have one. Its not good. not powerfull with like 125mW@32ohm. take a WALNUT V2S or Zishan Z2 instead....its more powerfull and can be used as a DAP too. It's smaller but thicker.
Great find, man! Did it give a bit more juice (and bass) to power your HE400se? Looking to buy that - thx in advance!Anyone ever heard of the sub-60 USD Bluetooth Desktop DAC/Amp, KGUSS BH3?
Well, for those that are curious, I have it here
ES9038Q2M
CSR8675 (Bluetooth 5.0; LDAC-capable)
2 x JRC-5532DD
WIMA and Nichicon capacitors
Initial Sound Impressions:
Warmer than neutral DAC/Amp, if comparing to my neutral-to-bright HUD100 MK2. Midrange is a treat with this one - weightier and more pleasant (fatigue-free). Treble's less harsh and smoother so it is very easy to listen to badly recorded tracks. However, the BH3 does add mid-bass warmth. Will be dependent on preference and needs. Clarity and transparency are adversely affected.
Can't determine yet it's effects, if there are any, on the other aspects of SQ (technicalities and such) as I've only had them for a day. So just the initial signature for now.
Driving Power:
Don't have measurements but have tested them with IEMs and headphones. Currently do not have high impedance earbuds. My usual listening volume is low-medium.
*In clock hands (o' clock). Just estimates as there is no marking.
HIFIMAN HE400se - 9.8
HIFIMAN DEVA - ~8.3
KZ DQ6 - ~7 (exception as it is at medium volume)
Moondrop SSP - ~7.7
*Compared to HUD100 MK2 (bypass, high power). Same order. n/100.
- 29/100
- 17/100
- 1/100
- 8/100
*Please take this with a grain of salt as this was done by ear only
Does it "open-up" the planar headphones? To an extent, yes.
Is there hiss with rather sensitive IEMs? With the DQ6, hiss manifests at 12 o' clock when not playing anything.
Are the components (op-amp, capacitors, etc.) legit/authentic? I have nooooo idea.
Forgot to mention - this is a BLUETOOTH DAC/AMP. My phone recognizes it as AAC/SBC/APTX/APTX-HD/LDAC capable. However, for some unknown reason, I can't activate APTX-LL, even through developer options. Bluetooth connection is very stable, without any random disconnections. Distance, as well, and I was able to walk around my house, phone in pocket, without losing connection (will of course depend on device used).
Build is all metal, even the volume knob (satisfyingly smooth turning). Has rubber feet so the BH3 sliding off your desk is not a problem.
Packaging is nondescript - just a cardboard box with a USB-C cable, antenna and the BH3 itself.
Op-amp appears to be hot-swappable but I haven't tried removing them from the board. I think it can also function wired through USB-C but that testing will be reserved for another day.
Interestingly, with the DQ6, there is a noticeably big loudness jump from the lowest volume, ~6 o' clock and 7 o'clock. Also perceivable channel imbalance in that "gap" but disappears once you get past said gap. With the other IEMs I have, this phenomenon wasn't observed.
Bought it here. Check Lazada store for more details.
