NymPHONOmaniac
Oh, this one look like a USB Dac, just plug and play I guess...sound to be turn via laptop...But... it doesnt have any button xD how do you use it¿
So, I make an impulsive purchase for testing something really really cheap but that use same Dual DAC chip than Cambridge Dacmagic....
it do not have metal case but can be plug right way by USB.
http://www.ebay.com/itm/252298238894
Just the dual TDA1305T worth the price...
Will try other ultra cheap DAC of this type if it sound any good!
I'm especialy curiou about AK4490 DAC soundsignature...so will check for the cheaper possible one to buy.
So I finally receive this extra nude DAC-(semi)AMP....and man....what the heck!!!!!!!!!!!!!Wow, that looks promising for the price.
Let us know ASAP!![]()
It sound freaking GOOD!
It's just fast impressions with my Koss Portapro but the quality of sound surpass any hope I could have, I just buy this for the ''amp lab'' but this is by far a very competent DAC no doubt about it, warm, extra clear, black background (no hiss even if no casing!!!), it's a plug and play and volume control work well, no need of extra amp for easy to drive but it will open up the soundstage...Dual TDA1305t sure sound like honey to my ears, it's smooth and sweetly textured, mid and low centric, not clinical, analog style I guess....wow man, i'm on a new very interesting quest here!!!!!!!!!!!!!!!!!!
20$ and perhaps it sound better than the 250$ Ibasso D2+BOA I just buy cause I like Wolfson WM8740 sound! Anyway, the amp isn't, cause it's a DAC with a little amping (enough for 64ohm and less).
(bad pic, too lazy to get up and find better lighting)
There you go:Link please.
Yeah, it sound wider but a little warmer too, it all depend the amp you have I guess, mine its ibasso D2+ Boa and is on the warm side already, anyway I use it with good result for full size headphone and sound is way way way better than my computer soundcard. For iem, it work really well without amp, no hiss at all wich is very impressive. 18$ and it include otg conerter cable and a quality usb cable...I don't quite understand the genorisity of this Douk Audio shop!!Does it sound fine with an amp? I guess if using the headphone-out to an amp it would be double-amping, but it wouldn't matter much if its amp isn't very powerful. ?
Does it work with Android phones and OTG cable?
I've asked the seller and no, apparently it doesn't. Maybe it was obvious, but I'm not familiar with such devices.
So, what's the cheapest solution for a good sounding USB DAC that works with Android phones?
By experimental i mean stuff like this intriguing ultra cheap DAC:
http://www.ebay.com/itm/272563718422
You can ask this seller if it work with Android....
