- Apr 9, 2011
5770. I can run BF3 on high with 1080p
What are you running?!?
I wonder if mine would look better at DS and 2x since I down sample mine from a higher rez. Also, Most games run 4x DS fine, with the exception of BL2 and SR3 so far... I really want a 680!Just make sure to resize them with photoshop or something. If you're sticking with 100% view size, or using your browser's zoom setting to get the images the same size, you might not be getting the proper quality comparison. If one of them is zooming to a weird size (like 64% or something), it's not going to properly crunch the jaggies, making them worse!
EDIT: A quick side-by-side.
The lower resolution, higher AA one definitely looks better.
I run Arkham at ~15 fps at that... I should have bought Crysis 2 for $10 the other day, but I had no money.
Where at??? That would be fun! I'd do that without getting Crysis for cheap!I run Arkham at ~15 fps at that... I should have bought Crysis 2 for $10 the other day, but I had no money.
I bought Crysis 1 for $1 by posing as an Australaian!!! heck yeah!
Where at??? That would be fun!I'd do that without getting Crysis for cheap!
Sleeping Dogs maxed out on everything except FXAA at 1080p with a custom SweetFX profile. Looks great, playable frame rates of mid 40s as well.
