godlikegamer
- Apr 4, 2015
I am very good friends with Geronimo Albus Oriolus, the founder of Oriolus.
Does the earphone made by mini audio??
I chose the Oriolus in the end! I found that the Oriolus has a more chaotic yet lively sound. It also has a bit of a bump in the mid-high range that pushes vocals more forwards which I kind of liked as well. Merlinv2 has a more controlled sound with slightly softer highs IMO, oriolus highs are clearer and heavier hitting. I think the Merlin has edges out Oriolus in terms of a solid bass, but loses out in engaging mid-highs to highs. I hope this helps! I don't regret my purchase at all, they're simply different sound signatures.
^ Glad you liked them. If you don't mind me asking - how do you find the Oriolus fares against the A91 in terms of air and spaciousness? I've recently realised that the reason why I liked the Oriolus so much was because of how airy and spacious they are, so if the A91 can match or even exceed the Oriolus in these regards, then they may just be worth a shot.
I don;t mind at all. I am still just getting to know both of them, as they were part of a binge purchase which also included the Z5s. This all came about because I pulled my original version AKaedes out of storage and gave them a listen after a steady diet of multi-b.a. ciems....
That said, I think the A91s present a bigger soundstage, that sounds 'airier', but the Oriolus is more focused, and has more papable 3-d images. In the speaker world, you usually have to chose between a big stage and a focused one. I am trying to get the most realism, where I am tricked into believing I am present at the actual live performance.
They are both good, but different. Both give me fit "fits".
Just got back to work from a coffee break, where I swapped cables and tips, and fired up my Hifiman 901. Ended up liking the UE900 tips and the stock so-called "Chinese" cable (the silver looking one). It's very slinky and does not try to lever the iems out of my ears, or break the seal. It was an amazing combo, even though they still need to be nudged back into place from time to time...
I'll try to play the A91s with the 901 and see what they differences are. Both are good, but I think I like the Oriolus better- but I have much more work to do to sort this out.
I've been on the fence of buying these because I have the A91 and the Andromda, but I think your response made the decision for me. I'm glad they are different than the A91, and it sounds like owning both could make sense because you can use them in different situations for different sounds.
