rafabro
- Oct 28, 2016
Is modded Sonica better then modded LKS 004?
Ric indicates that to be the case currently. But he is working on more mods from what he has told me that may change that. Best to talk to Ric to find out. He may even have some more Sonica mods in the near future. Ric never rests seemingly..he is always about improving the sound. Besides it is fascinating and entertaining to talk audio with him. The EVS Sonica is my endgame for awhile. But if Ric has another round of tweaks for it I'm still in the game!Is modded Sonica better then modded LKS 004?
Very happy.
PC or direct-connected USB drive ==> Sonica ==> Violectric 280 ==> HE-560 -- balanced all the way
Can't really provide any before/after comparisons, since I got it done quite soon after I received the Sonica, and didn't have the Violectric until after Sonica was out for mod.
Still liking the Sonica running balanced to the V280?
Yep -- very detailed, with wonderful open, airy image on my 560s. Lush, lovely, musical.
Finding my T1 2ndGen a bit fatiguing. Could be the Sabre + Beyer brightness. Or, maybe the OPPO has nothing to do with it. Same story with my Plenue 2 (AKM 4497) and x5iii/AlgoRhythm Duet (AKM 4490). Both the AKM DACs are neutral/warmish. Maybe I just can't tolerate the T1.
Gonna try the damping mod on the T1.
I wonder if a Chord TT running cheap Canare balanced cables around the room to my...
Dunno maybe this will be of interest for some on a tighter budget:
https://hifimediy.com/news/New-Sabre-ES9038PRO-Chip
The few commercially available DACs using this chip are all quite expensive, which is understandable as the chip is more than 10 times as expensive as the ES9018K2M chip!
I had the T1.1 and actually prefer the DT 1990 Pro. If you haven't tried that headphone please do. Highly considering the Oppo Sonica as my first hifi DAC. Does the ES9038Pro really make that much of a difference vs the ES9028Pro that's in the Gustard X20 for example? Obviously the chip isn't everything it's also how it's built. The Denafrips Ares R2R is also interesting.Yep -- very detailed, with wonderful open, airy image on my 560s. Lush, lovely, musical.
I think that what someone else mentioned is correct in that you have to spend at least a week or two with each DAC to really realize a difference. Once you get used to one sound signature you'll either dislike or like the other better.HERE I just compared Burson Conductor ES9018 to Sonica, Hugo and Mojo.
Just using pure A/B blind tests with TH900 and HD700 I found zero difference in sound between Burson all in one ES9018 DAC and Oppo Sonica RCA to Burson's AMP.
No measurements, thinking, believing - just pure subjective seamless listening side by side.
I respect every opinion, but my own is that's the is nothing but placebo effect and marketing strategy.I think that what someone else mentioned is correct in that you have to spend at least a week or two with each DAC to really realize a difference. Once you get used to one sound signature you'll either dislike or like the other better.
WIth headphones I hear immediate difference between X00 and TH900, and even between different batches of X00.
But with DACs on the same song I cant spot the moment when DAC is changes. That's not the case when I'm ABing cheap pc motherboard or cell phone DACs. It applies only to HighEnd DACs I've tested.
So my idea is that all these DACs, 9038, 9018, Chord perfectly recover analog signal, they may use different technique but resulting analog signal is the same, at least to my hearing. They may measure differently, but measurements and hearing are 2 different stories.
I cant say anything about AK / Burr Brown or Wolfson DACs since I haven't tried them yet, but for ESS array and Chord Hugo they're same to me. If one DAC claims to be warmer that the other then I have to notice that immediately, rather that using this for a week to start believing in warmness.
BTW if anyone can recommend the warmest DAC on a planet so I can test it with ESS side by side?
Well, after all the most important thing is to be happy with the setup. The only thing worth investing in HiFi gear is happiness.There are pretty clear cut differences between each generation of Sabre DACs. The Sonica with a 9038 is the best dac stock I have heard. But upgrades from EVS have shown me it is nowhere near perfect, especially in stock form. It also improves substantially with an Ifi Galvanic 3 and Wyred For Sound RUR reclocker.
No doubt there are more improvements possible. I know that a dedicated PCIE USB
Card also makes a difference as well. There are also a number of more expensive implementations of the 9038 that would beat the Sonica. I am pretty happy with my current setup...but I am under no illusion that it is perfect
