jgwtriode
- Mar 10, 2012
Well, after all the most important thing is to be happy with the setup. The only thing worth investing in HiFi gear is happiness.
About external usb cards. If regular USB port does not introduce any interference and background is dead black, then what is the purpuse of expensive usb cable and external ports? If you have some hissing noise while using internal USBs then yea it does make sense, but otherwise? Does it have an impact on sound quality?
Personally I have some hiss from USB w Sonica paired with Burson Conductor when USBs are connected on either side. External USB may fix that, dunno I dont have that card currently. But if I feed Burson with Tosling from Sonica with USBs disconnected in both devices - background is dead black.
Your explanation of how you connect your devices is confusing...nevertheless the point of a dedicated PCIE USB Card is to get it off the dirty noisy bus and power supply of your computer. It runs with a seperate power supply from the computer.
You may think you are hearing black noise free USB from your computer. I can assure you that you would not say that if you run your USB from a dedicated card with seperate power supply. Even the basic Paul Pang V2 will easily let you hear the difference!
