Oppo PM-3 : The Portable Planar - Impressions
360 361 362 363 364 365 366 367 368 369
371 372 373 374 375 376 377 378 379 380
  1. noplsestar
    There is no gluing needed at all. Just remove the original pads completely. Then pull over the new ones over the whole capsules. It’s done within a minute. Only if you want them to look exactly like the original you would have to do the gluing thingy.
  2. megabigeye
    For the headband replacement, Beyerdynamic has replacement pads for their headphones that might work. Or maybe this one? They have others, too, but the ones I linked look nicest (to me) and seem like they'd be simplest to try. Don't know if the DT 770/880/990 have the same sized headband, but my DT 1990 is just about the same size as the PM-3.
    I was also looking at Reddit, and people were recommending fixes like bicycle/tennis racket grip tape, iron-on patch cloth, and even heatshrink fabric tubing.
    noplsestar likes this.
  3. BlueWindNoise
    Yeah, you have to cut out the mesh in the original pads which makes them unusable. Then you glue the new pads on, yes.
  4. Guppy_
    Ah might be worth looking into, thanks!
    Lol make up your minds guys, do I have to cut or not?
  5. BlueWindNoise
    If there is a way to remove the original pads without ruining them, I don't know what that would be. I had to cut them off. The original pads are ruined. I glued the replacement pads on. I understand there is another option but I wanted them to look stock and for that, you have to glue them on. It's really not very difficult and the approach is determined by how you want them to look in the end.
  6. megabigeye
    I thnk
    I can't find the post now, but I swear somebody said that they just attached the new pads directly to the cup, without taking the old pads off the clip ring. No trimming of the Brainwavz either. Might be a way to temporarily try the mod without damaging anything.
    Aha! Here it is.
  7. noplsestar
    Haha, you are funny. Of course you have to take off the original pads (inclusive the clip rings). You don’t need the clip rings, if you want to add the new Brainwavz pads EXCEPT as many times mentioned, if you want to have the exact same looks as the original pads, then you would have to take off the original pads from the clip rings and glue on the Brainwavz pads onto the clip rings.
  8. megabigeye
    I think we're on the same page...
    1) Unclip clip ring/earpad from headphone. Leave this part intact for now.
    2) Install Brainwavz pad directly to headphone, without clip ring.
    3) Return or make more permanent as desired.
    4) ????
    5) Profit.
    noplsestar and alphanumerix1 like this.
  9. Guppy_
  10. noplsestar
    Sure, the non angled version fits as well, but I would highly recommend you buy the angled version, because it increases not only soundstage but also the comfort, so your ears won’t touch the inner earcups.
  11. BlueWindNoise
    This. I don't know how the non-angled versions might fit, but the angled fit great and there's no more touching.
  12. Guppy_
    Never worn angled headphones, how are these worn, angle facing back or front?
  13. noplsestar
    The angled (the side where there is more of the foam) is at the back.
    Guppy_ likes this.
  14. alphanumerix1
    I've had the pm3s for a lil while now and I'm noticing on some tracks they sound very compressed and congested (out of my wm1a) se output.
    But the same track sounding open and clear out my soundcard. Which is interesting does the pm3 scale up with more power?
  15. megabigeye
    Yeah, I've found they scale some. They don't seem to need much power, though. When I first got them, I used them straight out of a first gen. Fiio X5 and thought they sounded congested, like you said. Particularly on busier, more complex tracks with some bass. I got the Fiio E12A and it sounded much better.
    alphanumerix1 likes this.
